Question about Harley Davidson Watches
Links to a bulova watches band - Harley Davidson Watches
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
SOURCE: i need to add 2
Contact Bulova for additional links, 800-233-3350. You will need the watch model number and the case number (it's in the back beginning with "C".
Posted on Aug 20, 2008
escapement
  • 2334 Answers
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
  • 492 Answers
SOURCE: Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
Posted on May 09, 2009
lazydave
  • 68 Answers
SOURCE: how do I take out links to size my bulova tfx
You have to press the pin out of the side of the ban. I use a tool they sell at harbor freight tools to do it. If you dont have a harbor freight near you they have an online store. You can also use a good push pin and a small hammer to tap the pin out. Put the ban on it's side over a small hole drilled i a flat piece of wood so the pin can come out without bending. do this for each link you want out then tap the pin back in on the last link to put it back togather. Sometimes there is an arrow on the inside of the ban showing you the direction to drive the pin out
Posted on Oct 03, 2009
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Jan 31, 2016 | Timberland Mens Quartz Watch Qt7117302
Need to replace or repair a Bulova watch band C877668. One of the links broke. Stainless steel backing
I took mine to a watch repair shop but make sure your watch is worth repairing as it's not cheap.
Dec 31, 2015 | Bulova Watches
Extra links 96r000
You can go to any jeweler that handles Bulova watches and talk to them. I don't know if they will have the extra links but they might depending on how popular the watch is. They would also be able to show you other bands that can work for you and that watch.
May 16, 2015 | Bulova Watches
Remove links from metal band
Take your item to a watch repair facility where they will remove the links and have you sized up on the spot, maybe at no charge.
Dec 31, 2010 | Bulova Watch
How to take out links on aw223
I dont know what kind of band it is. But here is a link to some basic watch band sizings:
http://www.webwatches.co.uk/how_to.htm
Aug 19, 2010 | Bulova Watch
I have a Sweda watch with a link type band and I need to make band smaller.
Click on my profile (escapement), then click on Tips and Tricks. There you will find explanation how to remove or add bracelet links. Rate me, plz.
Feb 11, 2010 | Bulova Watch
I need to add links to my caravelle Bulova watch band G960472. Where can I buy the links? I need maybe 3 or4
You will likely need to go to a jeweler that carries Bulova or Citizen (now owned by the same company) as most after market parts are only available to retailers. Also, you may want to check for a used or broken one on EBAY or somewhere, then you can replace the links inexpensively.
Oct 17, 2009 | Bulova Crystal 96L000 Watch for Women
Link removal from band
if you don't have the necessary tools or knowledge then your best bet is to take it in and have a professional remove the link(s) for you. It all depends but sometimes if you take it to Macy's or Neiman's they will do it for free.
May 23, 2009 | Bulova Watch
Watches Logo
16 people viewed this question
Top Harley Davidson Watches Experts
Jimmy Accardi
Are you a Harley Davidson Watch Expert? Answer questions, earn points and help others
