Question about Barnett Crossbows Barnett Quad 400 (18071) Crossbow Package with Red Dot Scope
Need replacement limbs for Barnett quad 400 - Barnett Crossbows Barnett Quad 400 (18071) Crossbow Package with Red Dot Scope
2 Suggested Answers
SOURCE: I just assembled my Barnett
arrow has to be in it and you push forward on the safty.
Posted on Sep 24, 2011
What does sl mean when we talk of a horton crossbow
Street Legal.
Just kidding.
Solid Limb. As opposed to a Quad Limb.
Jul 15, 2014 | Horton Thecrossbowstore: Crossbow Lite...
Squeaking noise when drawing back Barnett vortex bow
The four rubber grommets where the string is attached to the limbs need some DRY lubricant. When drawing, the grommets 'slip', and that slip 'plucks' at the string creating the creaks. Keep applying dry graphite to these points and the bow will quiet up nicely.
Aug 21, 2013 | BARNETT OUTDOORS LLC 10 Barnett Vortex...
How do I adjust the draw weight on a barnett vortex lite junior bow
There are two bolts that hold the limbs onto the riser. Tighten them all the way tight or clockwise. This will ensure they are the same. Now you have to turn both bolts equal turns up to no more than 3 turns out. The looser the less weight. Never loosen more than 3 turns.
Dec 26, 2012 | Barnett Outdoors Barnett Vortex Lite Youth...
The fibers on my Quad 400 limb is pealing away
This is called delamination. Contact Barnett and they will repair or replace for free. lifetime warranty.
Oct 30, 2012 | Barnett Outdoor Archery
I bumped the right limb on a tree and have been shooting right about six inches
Make absolutley sure you didnt crack the limb. This could be very dangerous. If its not cracked , can you not just re adjust your sights ? The vibration could have just knocked them off.
Oct 24, 2012 | Barnett Crossbows Barnett Jackal...
Clutch
new procut basket and barnett plates. Had to file the barnett friction plate tangs they all slide but are a tight fit. All plates installed carefully per the Barnett instructions. Started the bike in neutral all fine shifted into 1st clutch in, I feel the bike want to creep forward although just slightly (I can hold it with my feet down). Can't get to neutral again with the clutch in until I shut the bike off. So, just before I go back in and pull a plate out to make the clutch pack smaller, i wondered whether anyone here has had this problem and whether if I ride it like this for a short while whether the clutch pack will settle in and fully disengage?,A too-high overall thickness of the plate stack will cause drag between plates when the clutch is disengaged making it difficult to select neutral when the bike is stopped. The last 2mm steel plate can be interchanged with a 1.5mm curved plate facing away from you if you want to adjust the stack to get the 38mm stack thickness, or if you want a more progressive, soft clutch engagement. A commonly-used substitution that adds an additional spring plate to the stack. Any of the steel 2mm plain plates can be exchanged with 1.5mm plain plates to reduce stack thickness or increase stack thickness as needed to achieve your desired overall height. You will see the need for this as friction plates wear, so keep your steel plates from pervious clutch replacements as spares to be used as height adjustments later. The 2mm and 1.5mm steel plates only need replacing if they’re scored or warped.,,,
Nov 10, 2008 | 2002 Ducati Monster 400
Barnett Crossbows Barnett Quad 400 (18071) Crossbow Package with Red Dot Scope Logo
423 people viewed this question
Top Barnett Crossbows Sport & Outdoor - Others Experts
Bill Eager
Are you a Barnett Crossbows Sport and Outdoor - Other Expert? Answer questions, earn points and help others
