Question about Bernina 2500DCET
Thread Brother 2340cv coverstitch machine - Bernina 2500DCET
Thread breaks on the 2340CV Brother. Doing two needle and the right needle is breaking at the needle. Change needle and retreaded several times
Probably depends what that needle is hitting that is causing it to break. Make sure the presser foot and the needle plate hole are large enough to accommodate the twin needle. Twin needles come in different widths so if yours is too wide, it would break. However, it could be possible that your machine is slightly out of alignment that does not show up until you try to use a twin needle. Also, make sure that your thread is not causing the needle to break--could be misthreading. Some machines have separate guides and tension disks for twin threads. Those that don't have that accommodation may have more difficulty using a twin needle.
Mar 07, 2017 | Sewing Machines
Huskylock 936 coverstitch will not form stitches
I just went thru the EXACT same thing, pulled up YouTube videos and discovered it was all about (1) how the LOOPER was threaded (the video taught me it is called "the puppy dogs head/ears" and that to thread it you follow the path of the ORANGE DOT (which often is combined with either blue/black, but just look for the ORANGE dot path no matter what the other color is with it) and that thread goes: "Around the puppy dog's neck and behind his ears". Honest to God this was part of my problem. (2) TENSION settings: I also discovered that even though the 936 has the adviser has all recommended settings for the stitches, you still NEED to tinker with the tensions. Specifically, I was set up for the WIDE COVERSTITCH to hem a knit skirt. I selected the KNIT MEDIUM (Auto M4) stitch and used these tensions: A needle 4, E needle 6, Looper was ok at 3. It worked like a charm and FINALLY I can do the stitch! Seriously, there are many YouTube videos (many lousy quality) that actually show and explain this stitch and how to set up your machine. Hope this helps!!! Good luck and happy sewing!
Feb 25, 2012 | Husqvarna Huskylock Computerized 936
Can you do a coverstitch on the Brother 634D serger
I don't think so, the D in your model name would denote that it has Differential feeding but is probably a 3/4 Marrowing stitch only. So this means it would do 3 thread overlock, 4 thread overlock and you can probably set it up for rolled hemming too.
Coverstitch is fairly new to home sergers and is available on some machines along with the 3 and 4 thread stitches, but changing between the regular overlock and a coverstitch takes a few minutes. The model number will usually have a "C" in the name. Also, during coverstitch the blades are disenaged and don't trim your fabric so you still need often to go back with blunt scissors and trim the raw edge.
And sewing coverstitch can be finicky, with skipped stitches a problem. Use high quality thread and XL (extra long) or SUX (stretch extra long) needles to avoid this.
However some manufacturers are now making dedicated coverstitch machines; if you are assembling a garment with your regular serger, you can then just move over to the coverstitch machine to sew the hems and necklines and not spend 20 mins changing over your machine's functions. Much more productive.
You may wish to check out the Brother 2340CV, this is their dedicated domestic coverstitch machine. Link to product info is http://www.brother-usa.com/homesewing/ModelDetail.aspx?ProductID=2340CV
In the meantime, best solution is a twin needle to stitch the hem from the right side of the garment on your regular sewing machine, looks much the same, and you can get twin needles with a 4mm or 2.2 mm gap and in stretch and sharp tips for less than $10 each. Just iron up the hem about 1.5cm deep, and thread up your sewing machine with the twin needle and two spools of same colour on top (I just wind an extra bobbin and use this plus the original thread spool rather than buy two spools).
Just sew really slow as the twin needle builds up a lot of heat and will break if you push it along. I use this finish on all my knit garments and it works just fine. Sometimes I'll iron in a 2cm strip of fusible web inside the hem to give it some firmness in a neckline, then twin needle stitch at about 1.7 from the folded edge.
Hope this answers your question.
Oct 23, 2011 | Janome MyLock 634D Mechanical Sewing...
Coverstitch tensions to tight
Coverstitch machines are very particular when it comes to thread. Use only MaxiLock cone thread. Do not use TruSew or SureLock thread. This can make the difference between working beautifully or not at all.
Jul 11, 2009 | Sewing Machines
Skipping stitches on coverstitch machine
To avoid skipped stitches on a coverstitch machine you need to use ELs (extra long) or SUK (stretch) needles and good quality thread. Poor quality thread is too fluffy and varies in thickness which can cause stitch problems. Try Maxilock thread from a cone or use maxilock on looper and regular sewing machine thread through needles and see if this improves the stitches. Also loosen off the lower looper tension to zero and see if this helps. If you are hemming around a garment and sewing across an overlocked seam then you need to minimise bulk too. lightly press the seams into the diretion you want them to sit when garment is finished, press the hem up, then force the seam allowance in the hem turnup area to the opposite direction. This spreads the seam bulk in both directions.
There is a knack to coverstitch machines but a good cover finish is quicker than twin needle on SM.
Apr 04, 2009 | Janome 900CP
MyLock 134D coverstitch?
While the ML134D is a very good entry level overlocker/serger, for coverstitch you will need a different or dedicated machine.
Janome has recently introduced a new model that is a combined Professional Coverstitch/Overlocker it is model 1200 D (Link) and is truly amazing in the diversity of stitch options
Their other coverstitch only machines are the CoverPro 900 & 1000 www.bargainbox.com.au
Dec 14, 2008 | Janome MyLock 634D Mechanical Sewing...
Coverstitch
Cut all the threads above the tension disks and pull them all out. Then rethread from the very beginning making sure to thread in the Proper Order.
Aug 30, 2008 | Bernina 2500DCET
Coverstitching on White Speedylock serger
Your machine cannot do a cover stitch. Check the Brother website, they make a cover stitch only machine, it works much better than any of the serger/cover stitch combination machines, and it is a lot less money.
Nov 19, 2007 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
19 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
