Synaps 24" monitor - white screen. - Computers & Internet
2 Suggested Answers
SOURCE: Synaps 24'' MB24WKH LCD Monitor no image displayed
Thank you shad193. I've probably solved the problem with my MB24WKH thanks to your experience.
Posted on Mar 17, 2011
Synaps monitor
Your monitor could have had a power supply failure.
Dec 04, 2013 | Computers & Internet
Driver for Synaps mw9bbk
The flashing power light and very slow display is an indication that the internal power supply board is failing. This is usually caused by bad filter capacitors on the board. You should be able to repair the unit by replacing the bad capacitors.
Sep 25, 2012 | Computers & Internet
Screen is milky white from the middle down
That is not good, the LCD screen panel will need to be replaced, however to do this would not be cost effective, cheaper to replace the whole monitor.
Apr 19, 2012 | ViewSonic VX2433WM 24 inch LCD Monitor
I have a synaps monitor model mt9bbk. The screan will go black and power led will flash.
Display Power management is being triggered because no input signal was detected. Verify that the video source is connected and on. (Computer, notebook, etc).
- Try another computer or laptop that you know is working properly.
- Do you see any change on the screen if the display cord is completely disconnected (often a "Test" or "Check Cable" message appears). - Inspect the signal cable from the monitor - worn? Any places where the cable was bent to an extremely small (acute) angle? (less than 75 degrees?) Try gently moving the cable around at either end and see if you get a partial signal on the screen (while connected to the computer). If you do, the signal cable is damaged, if possible replace it. try: www.monoprice.com
Apr 14, 2011 | Computers & Internet
Dec 21, 2009 | Computers & Internet
My synaps monitor screen can only be seen when light is bright on it, think it had sun exposure due to open window
If it's an LCD, there are two light behind the screen. If they burn out, no light to see the screen. Replacement lights cost more then a new monitor these days.
Jul 05, 2009 | Computers & Internet
Display was working fine. Then the screen blanked
Used monitor controls to rotate through the connection options (e.g. VGA, DVI, etc). After second pass, the monitor cleared-up.
May 04, 2009 | Dell UltraSharp 2408WFP 24" LCD Monitor
Synaps Monitor Model MT5WBP
i had the same "no input signal",and tried all of the "fixes" i could find without any luck.nothing was helping ,and i kept getting the "no input signal" message.i once had a remote control that would get frozen up ,and the only way to get it working was to :remove the battery's and push-n-hold the buttons down to discharge all memory.and thats how i got my,synaps mt5wbp, to finaly work.here is the fix:while holding the monitor upsidedown{buttons up},remove the power cord.then,push-n-hold the buttons for 10-15 seconds.all of them.you dont need to do all at once but it may help.do them all. my,synaps mt5wbp, has worked fine ever since i did this ,so give it a try.good luck.this worked on other things to.like my frozen TV remote control.
Nov 29, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
