Question about Radio Communications
Serial number kpg 112d - Radio Communications
Serial
See in .txt file in the programming folder
Apr 27, 2014 | Kenwood Cd Radio Software Kpg-128d V1.30...
Kpg-158DK
Contact Kenwood's customer support and select the proper region and category for your device. They're generally very helpful.
Apr 21, 2014 | Kenwood Tk-2202.tk-3202,tk-3207 Software...
Can't program tk 3402u16p with kpg 159dn software
try KPG158D two versions of radio, two versions of software
Feb 14, 2014 | Kenwood TK-3302U16P
Join software group download yahoo
The software program is KPG-35D and you need a cable that is KPG-36. I can't help you with the software because it is copyrighted by Kenwood. You should try looking in the Yahoo Groups section for a programming group or Kenwood group. Many have found the road to enlightenment doing so (if you get what I mean).
Oct 04, 2013 | Kenwood Kpg-35 V2.00 Programming Software...
I can read code plug with KPG-112D but after saving a write attempt results in "The linked network file cannot be opened" error
Hi Warren,
To steer you in the right direction, may I suggest: join yahoo group specific to your radio Make/Model, there you will receive info from experts and as a plus, you can download manuals, schematics and other goodies.
I hope this helps you.
Regards,
Peter
Jan 31, 2013 | Kenwood Kpg-112d V2.01 Programming...
Programing KPG-56D
the software is a dos executable. copy it onto your media of choice and paste it into you your other PC. vista will not run this unless you install virtual pc2007 and load win98 in the vista environment. vpc07 is tricky because you have to set up conduits for the virtual com ports that link your physical port. some serial to usb adapters won't function for these. I have had fair luck with kenwood and vertex using this setup.
Dec 24, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Pioneer dvr 112d power calibration error
updated firmware will not help. this is a known issue with Pioneer DVR-112D, drive needs to be replaced. Contact Pioneer for a free replacement, here is the url http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Notice+Regarding+CD+Read+and+Write+Functionality+in+Certain+Pioneer+Computer+Drive+Models
The issue occurs only under limited environmental and use conditions that are not typical for most end users, so Pioneer anticipates that most users will not be affected. If you are not experiencing any issues currently, there is no need to take immediate action. The service issue does not pose any health or safety risk.
Pioneer is aware of a potential issue with the above drives’ CD (not DVD) read/write capability. Under certain environmental and heavy use conditions, the above drives may become unable to read or write to CDs. To address this issue, for any of the above model drives that become unable to read and/or write to CDs, Pioneer will provide a replacement unit (which may be a newer model number) at no extra charge, shipping prepaid, subject to the terms and conditions of Pioneer’s standard limited warranty(excluding duration).
Again, we anticipate that most drives will not be affected. However, if your DVR-1810, DVR-2810, DVR-X122, DVR-112D, DVR-112DBK, or DVR-112DSV drive becomes unable to read or write to CDs, please contact Pioneer Customer Service by one of the following methods:
Complete an online replacement request form and submit it online. Once your model and serial number are validated, you will print out the completed form to mail along with the affected drive.
This online form is for United States customers only. For Canadian residents, please contact Pioneer Electronics of Canada customer service directly at 877-283-5901.
Mar 07, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Radio Communications Logo
128 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
