Question about Texas Instruments TI-83 Plus Calculator
Graphing calculator help
I have a cord that came with my graphing calculator. I can't find where it connects to my computer though it has the same end you would use to plug in a mic on a mobile phone, if that helps.
  • bjtouhey Dec 10, 2008
    I also have this problem the only spots like this on the computer are the mic and headphone plug in. Do you have to get a different wire?
  • kakima May 11, 2010
    Does the cord have the same connector on each end? If so, that cord is for connecting two calculators. You'll need to buy the link cable from TI, or else make your own.
  • 218 Answers
The cord that comes with the TI-83 Plus is a unit-to-unit link cable. It allows you to share data from one TI-83 (or other compatible TI calculator) to another. If you have the optional TI-GRAPH LINK adapter cable and the appropriate software it can also be connected to a PC.
For more info, here is the link to the manual. Chapter 19 discusses it in great detail.
http://education.ti.com/downloads/guidebooks/graphing/83p/83m$book-eng.pdf
Hope this helps..and good luck!
Posted on May 28, 2009
SOURCE:
How do I graph x<-3 on the calculator?
First you must use a graphing calculator.
Most graphing calculators graph functions, i.e. relations of the form y=f(x).
Some graphing calculators are able to graph equations (not necessarily functions). On one of these calculators your draw the vertical line x=-3, then you shade to the left of the point x=-3. That gives you the real line from infinity up to but not including x=-3.
Generally, people do not need calculators to find the solutions to inequalities in just one variable.
Jan 06, 2016 | Office Equipment & Supplies
How to solve graphing equations
How can you graph equations (functions) if you do not have a graphing calculator?
Feb 12, 2014 | Texas Instruments TI-30XA Calculator
Graphing ellipse
This is not a graphing calculator. Besides, most graphing calculators are able to graph functions, and conics are not functions. You need a utility that graphs conics. The Casio FX-9750G and others have a conics utility. On the TI83/84 Plus you can download an application that draws them.
Oct 30, 2013 | Casio FX-115ES Scientific Calculator
I need an activation cod for graphing calculator 3d 3.2
hi, you can purchase from http://calculator.runiter.com/graphing-calculator/buy-graphing-calculator.htm
let me know if it works.
May 12, 2011 | Computers & Internet
We already have this calculator and need to know if it is considered a graphing calculator. Thank you, RH
While it may have many of the same functions as a graphing calculator. It cannot produce a graph on the screen. This is required for most classes. It is not considered a graphing calculator, and you will most likely have to buy a new one.
Aug 23, 2010 | Casio FX-250HC Calculator
How to use graphing calculator?
The casio FX-300Ms calculator cannot do graphs. To tell you how to use a graphing calculator TO DRAW GRAPHS we need to know the exact brand and model number of the calculator.
  1. Most graphing calculators basically function the same way.
  2. You select the graph type (function, polar,parametric, sequence, 3D, wire mesh, slope field, etc.)
  3. You enter the algebraic form of the function you want to draw.
  4. You press a button or menu to GRAPH
  5. The graph is drawn.
  6. If you want to see a particular part of the graph, you use a ZOOM function, or you enter values for the WINDOW dimensions.
  7. Most graphing calculators have a TRACE function that allow you to follow the curve you have drawn to read off values of coordinate points.
  8. You can also use the calculator to find zeros roots) of functions, calculate derivatives at some chosen points or calculate the area "under the curve", find the minimum and maximum of a function.
In addition to its graphing capabilities, a graphing calculator can be used as a scientific calculator. Sometimes it can also do statistical and financial calculations, matrices, list manipulations, operations on complex numbers, text editing,, creating programs etc.
Aug 13, 2010 | Casio FX-300MS Calculator
How do i calculate limits on my Casio fx-115es? Ex. lim x->3 for (x2'-0)/x-3
Sorry, but you cannot calculate limits of functions with this calculator. It does not have a Computer `Algebra System (CAS). For that you need a graphing calculator with CAS: Casio ClassPad 300, 300PLUS, 330, HP 48 GII, HP49 G/ G+, HP 50G, TI-NSPIRE CAS, TI89 Titanium, TI 92/92PLUS, TI Voyage 200 PLT. It is still a very good scientific (non graphing) calculator
However, you can calculate numerical derivatives, and numerical integrals, solve linear and non-linear equations.
Even though this post does meet your expectations, do not let that prevent you from rating it.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
Graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site
- doug garfinkel, Children's Day School
Jan 15, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-83 Plus Calculator Logo
159 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
