Question about Frigidaire AEQ6000ES Electric Dryer
Miele novotronic T565C the dryer door opens during operation
The door is opening during the cycle
4 Suggested Answers
  • 4 Answers
SOURCE: high efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Posted on May 30, 2009
  • 3074 Answers
SOURCE: after running for a cycle you open door of dryer
http://www.applianceaid.com/gas_dryer.html#noheat
Posted on Mar 04, 2011
  • 6468 Answers
SOURCE: frigidarie dryer door open
there should be a small switch that senses to door check on sears parts online to see what it looks like
Posted on Mar 26, 2012
How do i switch the opening of the door
there should be screw holes on the opposite end of door to reverse it?
Sep 12, 2014 | Miele Novotronic T1515A Electric Dryer
How to unlock washing machinge
Question is somewhat ambiguous, since in normal operation the door "unlocks" when the cycle is finished and the orange DOOR button is depressed. To manually open the door mid-cycle or with no power, find the yellow plastic tool attached to the soap tray and use it (or something similar) to pry open the front access panel at bottom left. There will be a plastic ring projecting downward into the cavity behind this panel: pull it sharply downward and the door should open.
Jul 11, 2014 | Miele Novotronic W1918A Front Load Washer
Novotronic t653c
You won't be able to swap the door around. However most dryers can be used upsidedown, which would make then door open the other way. Just your controls will be down the bottom.
Mar 28, 2014 | Miele Dryers
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
I need from manual guide on English for dryer Miele t565c
I have a t565c novotronic dryer,the light in the drum comes on but when i close the door and turn it on it want start .?
Dec 28, 2010 | Miele Novotronic T220 Electric Dryer
My dryer keeps stoping during the cycle and the door opens. Do you have any suggestion? Thank you very much
most likely you have a bad door switch your dryer will stop when the door is opened another way of by passing this switch would be to find it onthe inside of your dryer and connect the two wires together this is only a temporary fix your dryer would always run even withthe door open by doing this best thing to door is look online marone appliace call them give them your model number order a door switch ad you might even need a door latch also if your door is not staying closed hope this helps
Jul 13, 2010 | Miele Novotronic T220 Electric Dryer
Miele T230C do no start
If start LED does not blink, most likely fault is your door lock.
Jan 04, 2010 | Miele Novotronic T230C Electric Dryer
Stoped working
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
May 30, 2009 | Miele Dryers
Miele T220 Novotronic
Miele is a top notch machine. Try checking your vent hose. It may be blocked in some way.
Jan 28, 2009 | Miele Novotronic T220 Electric Dryer
Miele G660 premier dishwasher
There is a solenoid that opens the door to the dispenser. You can check it with a volt/ohm meter. Sometimes large dishes can block the door keeping it from opening. I personally know on some Whirlpool washers (because it was mine) that if the bottom drawer is put in backwards, it wont let the door open. When I opened the main door, then the dispenser would flop open. You need a meter to check this part if its not the other things. Without it, you are just guessing.
Mar 15, 2008 | Miele 24 in. Novotronic Premier 500...
Dryers Logo
22 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
