Question about Saeco Incanto Classic Espresso Machine
Brew unit wont go back in in seaco incanto - Saeco Incanto Classic Espresso Machine
  • 1,089 Answers
There is a flag on the back side of the brew unit. Below the flag are 2 plastic bars that the flag slides in. Push in between the 2 bars and see if the flag will drop. If it does holding the brew unit with your right hand, take your left hand and place it on the bottom left side of the brew unit, then with 2 fingers reach up inside the bottom and grab the bar in the center and squeeze the bar to the left. This will bring the cylinder back into position and align the 2 triangles on the front of the brew unit. Once they are aligned push the lever to the right to lock up the brew unit. Leave the brew unit out, but everything else in place, then turn the machine on. Once
the machine is settled open the door, remove the drip tray and then insert the brew unit, drip tray and close the door.
Posted on May 21, 2009
SOURCE:
Saeco incanto del luxe coffee machine dumps coffee into waste drawer
Your brew unit may be set in the wrong position inside the machine if someone has had it out to clean or try to fix. The unit has two positions open and neutral when putting back into the machine it should be neutral. This is something I would try first. Now if it is in the open position you will need to reset it. Resetting is better explained on video so I have put a link for a Youtube video. This guy is great and guides you through step by step. Hope this works for you good luck. Please post and let me know.
Cheers
How to Remove Stuck Brew Unit Q
Feb 06, 2015 | Saeco Incanto Classic Espresso Machine
Saeco incanto classic
http://www.partsguru.com/SaecoIncantoClassic.html
Apr 24, 2014 | Saeco Incanto Classic Espresso Machine
The display indicates "brew unit
Remove brew unit and check lever for microswitch at the top back of the machine, the lever might be broken or the micro switch is damaged and cannot read the brew unit when it is inserted.
Apr 18, 2011 | Saeco Incanto Classic Espresso Machine
Incanto stuck in the middle of brew process
No you will have to let the machine center itself, on the part that is out, if you look carfully you will noticw a small notch, and in the machine, if you inset a small screwdriver you will hear a click, that is the microswitch, there is one for the the door, that one will have to be pushed then the others at the same time, because if one of them is not engaged the machine will not do anything.
Nov 28, 2009 | Saeco Incanto Classic Espresso Machine
How to find & clean upper filter -Saeco Incanto Sirius brew gp?
If you are holding the brew unit in your hand with the words "Press" facing you, turn the unit right about 90°, and down 90°. Look above the dregs slide, you will see the filter screen under the red gasket.
Apr 02, 2009 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Odea Giro - Watertank
Yes that is perfectly normal. It has to have enough for a long coffee or steam. So it always has some to spare in the tank.
Dec 02, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
363 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
