Question about Tamron 80-210mm f/4.5-5.6 Lens
Does tamron 80-210mm work for Nikon d90 - Tamron 80-210mm f/4.5-5.6 Lens
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Tamron Master
  • 102,366 Answers
Tamron makes their lenses with a variety of lens mounts. If your lens has a Nikon mount then it will mount onto the D90.
Posted on Oct 26, 2014
5 Suggested Answers
  • 8 Answers
SOURCE: Tele converter option for Tamron 28-75mm f2.8
This is a lens for Sony/Minolta cameras. It is not compatible with the Nikon D90. Hence a Teleconverter for Nikon will not work on this lens to mount it to a Nikon D90.
Posted on Jan 15, 2009
  • 685 Answers
SOURCE: I am using a Tamron AF 18 - 250 mm lens on a nikon
Make sure the lens is set for the largest f number on the aperture ring. there may be a lock to prevent the ring from turning in the future. Locking the lens of the largest f number allow the camera to set the lens through the camera. This is normal on most of the newer cameras.
If the lens does not have a move-able aperture ring, then dismount and remount the lens, making sure the lens is completely mounted and locks into place, completely lining up the contacts inside. If this does not work The camera or lens may need servicing.
Posted on Nov 24, 2009
  • 3 Answers
SOURCE: Hi!! The autofocus on
As with almost all camera equipment and lenses I recommend that you do not, under any circumstances try to repair them yourself. Photographic equipment is very delicate and you could just make the problem worse.
The most comprehensive solution would be to contact Tamron itself and send it in for repair. If your product is under warranty you may only have to pay the shipping fees.
You can find Tamron's contact information here:
http://www.tamron-usa.com/contact/default.asp
I hope this information was useful.
Please let me know when/if you get this problem solved.
Posted on Mar 22, 2011
  • 3287 Answers
SOURCE: tamron 14mm 2.8 does not work on d90
This lens is compatible with your Nikon D90 according to this site:
http://lenshero.com/lens/Tamron-14mm-f2.8-IF-Nikon-f-lens
Your complaint "does not work" is rather broad, so I don't know what specific kind of problem(s) your having with it.
If you continue to have issues with it, make sure other lenses work on your D90 to eliminate the body as the source of the problem. Consider performing a 2 button reset on the D90 (and resetting any other customized settings to defaults) and try again. If it still "doesn't work" then contact Tamron to evaluate the lens for possible repair.
Posted on Jan 12, 2012
Is the Tamron AF08N700 auto focus with the D90?
Good morning. You have likely already gotten an answer to this, but yes, it will.
Unlike less expensive models such as the D40, D60, D3000 and D5000, the D90 has a built in autofocus motor, which means that all Nikon F-mount autofocus-lenses (except two for the rare Nikon F3AF) can be used in autofocus mode for all newer generation autofocus lenses like the Tamron 200-800. However, you may want to look around a bit, as Tamron has come out with a new 150-600 lens that is simply terrific (I know, I own one) and the Big Sig from Sigma is equally great.
FYI
Good luck.
Dec 05, 2015 | Nikon DSLR D90 Digital Camera
Is Tamron AF80-210 compatible with Nikon D3000?
This is the tripods and monopods forum, perhaps you would have more luck posting in the camera lenses forum.
Hope this helps
Sep 11, 2014 | Nikon D40 D40X D60 D80 D90 D3000 D5000 &...
Would a hoya Infrared R72 filter tamron 72mm lens
That would depend on the filter.
Since Tamron has never made a lens with a fixed focal length of 72mm, I assume the 72mm is referring to the filter thread. I also assume you mean the Hoya RM72 infrared filter. The "72" in the filter name is a description of the filter and has nothing to do with its physical size. One vendor lists the RM72 filter in sizes ranging from 46mm to 77mm. As long as you get the filter to match the thread on the front of the lens then it will screw right on.
May 29, 2012 | Hoya 72mm RM-72 Infrared Filter
Tamron 14mm 2.8 does not work on d90
Jan 05, 2012 | Tamron Super Wide Angle SP AF 14mm f/2.8...
Hello, hope you can help I purchased a Nikon D90 and a Tamron 70-300 lense about 2 years ago. The camera is working correctly, but when I connect the Tamron Lense the word err appears, in view finder,and...
Hi
Based on your description I recommend clean the CPU contacts both on the camera and on the lens.Due to dirty contacts the D90 probably won't recognize them. Try it and see.You can clean them either lens tissue moisted lightly with Kodak lens cleaning solution or carefully with Some very light amount (just moisture it ) isopropyl alchohol on a Q-tip . Just make sure and not leave any tiny strands of cotton behind.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 18, 2011 | Cameras
Hi!! The autofocus on my Tamron 79-300 for my nikon d90 dosn't work anymore. Can I fix it?? Is there any solution? Thank you, Lise gagnon
Mar 20, 2011 | Tamron Cameras
D90 Nikon autofocus problems
Try a reset (hold down both buttons with green dots next to them) and see if that helps.
Also try cleaning the contacts on the lens itself (light rub with a pencil eraser usually works well).
Jul 30, 2009 | Nikon D90 Digital Camera with 18-105mm...
Jan 15, 2009 | Tamron AF 28-75mm f/2.8 XR Di Autofocus...
Tamron 80-210mm f/4.5-5.6 Lens Logo
71 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
