Question about LG Televison & Video
Tv error codes 901004 - LG Televison & Video
Sony 50 in. tv bought in jan 1994 turns on i here sound last about 4secounds and turns off bliking light in front of tv blinks 8 times
im not finding an 8 blink error code in the service manual only 2,4, or 5. the tv will shut down and blink an error code. it will blink the code fast and repeat itslef. if you can tell me what the code is i may be able to assist.
Oct 22, 2007 | Sony KV-27FS13 27" TV
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
Is there and error code 12 and if so what is it please and thank you.
ERROR CODE 12 IS "NORMAL OPERATION" IF THAT IS THE CODE THAT THE TV IS GIVING YOU THEN IT THINKS THERE IS NOTHING WRONG WITH ITSELF. YOU HAVE TO CHECK FOR THE ERROR CODE ONLY AFTER THE TV FAILS. TRY TO POWER ON AND IF IT DOESN'T THEN CHECK ERROR CODE.
Dec 17, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Tv does not come on.the red light next to the
Count the number of blinks and that is an error code to allow you to diagnose a problem with the TV. Once you are sure about the error code, re-post here asking for what the error code means and how to fix it. Make sure you post the make, model of TV. I hope this helps and good luck!
Dec 03, 2009 | Toshiba TP50F60/61 TV
Tv says airflow restriction tv will turn off. there is no airlfow restriction
I did not find a reference to airflow restriction in the service manual.
I don't know if this will help, but here are the error codes:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
4. Error Codes
The Error Code designations are listed below:
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Oct 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Note:
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Error light
There is an error code that flashes on front of TV. which is in this case an error 7 which is power related. Also there is a gree LED on the power supply that will flash an error code also. If u look on the power supply U will see a list of numbers 1-13 which list the error codes and what they mean.Usually if it flashes 1-9 its usually cheaper to just buy another TV. because the Power supply , Y-main, X-main will probably run $300 plus core charge.
Mar 27, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
67 people viewed this question
Computer Repairing
Computer Repairing
