Question about Samsung UN40C7000 TV
Samsung UN40C7000 TV factory reset - Samsung UN40C7000 TV
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
Nov 29, 2015 | Samsung Televison & Video
Samsung LCD TV LE40R8 - Hard Reset
How do I reset the picture on my LCD TV to the factory settings?
The P.Mode button on the remote of your LCD TV lets you cycle through four factory preset picture modes: Dynamic, Standard, Movie, and Custom. To return the picture on your TV to the original factory preset, press the P.Mode button on your remote until the TV displays the Standard mode.
Nov 14, 2007 | Televison & Video
My Samsung tv wont record any more?
Contact the authorized service center for Samsung.
Before that, try a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 03, 2015 | Samsung HL-P6163W 61" TV
I have a cable paid for but My male coaxial cable from the wall doesn't fit into the antenna-in on the UN40c7000. It seems I need a coaxial cable adapter. I can't find the right size. How can you help?
Is the connector coming out of the wall too big or too small for the connector on the TV? If too big you should be able to still plug it in it will just be loose, and you can check that your signal is working etc.
This is very strange as coaxial cables have a very standard size, and do not vary. Unless it is a mini coax cable which is very tiny and right off the bat you can tell it wont fit. If that is the case then you need to get a converter.
Otherwise you may be able to use something like this http://www.amazon.com/10pcs-Frequency-Barrel-Connectors-Couplers/dp/B0037JB75S/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1381528325&sr=1-1-catcorr&keywords=coaxial+barrel
and tape the one end and use a regular cable to your TV. I would first purchase another cable and ensure that it will fit on the TV to ensure the connector on the TV is indeed the right size.
Oct 11, 2013 | Samsung UN40C7000 TV
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
Need to unlock vchip passcode; factory reset?
v chip block just popped up on screen , and i never set the tv to v chip
Apr 27, 2009 | Samsung Televison & Video
Samsung UN40C7000 TV Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
