Question about Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Electrolux EI27BS26JS ice maker not working - Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Electrolux EW28BS71IS ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
sfgs
Posted on Sep 30, 2010
  • 1891 Answers
SOURCE: French Door with bottom freezer Electrolux ice
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Posted on Dec 11, 2010
Electronic Board questionable
Do you have the model number of your refrigerator? Ice makers will not work if the freezer is not below 5 degrees Fahrenheit or -15 Celsius They also fail themselves or not working because the water control for the ice maker side is not working. Not likely a control board unless the board in built into the ice maker
APPLIANCE 911
Jan 02, 2016 | Electrolux Refrigerators
How do I get the ice maker to work. It has been out for 8 months.
There have been several service flashes on Electrolux ice maker repairs in recent years. Contact Electrolux customer support with your model, serial number, date of sale and service history and ask for assistance. They should be able to direct you to a certified serviced with experience in this area. This support is available at (800) 435-3287 or http://www.electroluxappliances.com/Owner-Support/Contact-Us/
Sep 12, 2014 | Electrolux Refrigerators
Electrolux ice maker won't stop making ice
The bin full detector is not working--replace it.
May 21, 2014 | Electrolux 15 Under-Counter Ice Maker...
Ice maker stops making ice
heatman101
Oct 23, 2010 | Electrolux EI23BC56IS (226 cu ft) Bottom...
heatman101
sfgs
Jun 24, 2010 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Ice maker has stopped working. Very hot here in Atlanta.
heatman101
uit45
Jun 20, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 17, 2009 | Electrolux EW23CS65SS Stainless Steel Side...
Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
37 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
