Question about KitchenAid KIRD801VSS Stainless Steel 27" Kitchen Hood
Kitchenaid downdraft will not retract. It is up and working, but button will not make it retract. How do I get it to stop? Model# KIRD801VSS-1.
4 Suggested Answers
SOURCE: Kitchenaid downdraft retractable vent
Your drive motor arm is not making contact with either of the two limit switches at 6 and 12 positions. Your arm may be loose, gear stripped, broken bracket. Turn off the power at the breaker panel and remove the vent pipe cover box (4 nuts) see what is going on inside. Tellstar
Posted on Feb 03, 2010
SOURCE: Downdraft vent won't stay down. Push the button
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Posted on Mar 20, 2010
SOURCE: Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Posted on Nov 25, 2010
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
How do I fix KitchenAid Retractable Downdraft Vent System?
No model number but they are pretty much all the same you have a failed micro switch behind each filter screen is one rarely see them go bad but filters have to be in place for unit to work, depending on model there are either two or three switches around the motor they are pretty aggravating to get to they are located in the panel below the cook top some models require the removal of the blower motor and housing and depending on the install still my not be able to remove the main panel if you can get past all of this to the switches don't waste time testing them just change all of them they get grease in them which won't allow the contacts to mate
Jan 23, 2015 | KitchenAid Dryers
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
Model KUDS30FXSS1 Kitchenaid dishwasher control panel stopped working at the end of a cycle.
I had a similar problem: unresponsive buttons, then the 1 hour wash button led was on but the other buttons weren't working at all.
I power off for more than 30 seconds and after that everything return to normal.
Thank you for the hint!
Nov 03, 2012 | KitchenAid Dishwashers
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
My viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
Dec 20, 2009 | Viking Kitchen Ranges
Downdraft vent won't stay down. Push the button and it retracts normally, then pops right back up?
Aug 27, 2009 | KitchenAid KIRD861HSS Kitchen Hood
Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
Mar 01, 2008 | KitchenAid KHTU165RSS Stainless Steel...
Filters for the Kenmore Downdraft Blower
CAN YOU PLEASE GIVE ME THE RIGHT CUTOUT FOR THIS DOWNDRAFT
Nov 13, 2006 | Kenmore 59940 Kitchen Hood
Open Questions:
KitchenAid KIRD801VSS Stainless Steel 27" Kitchen Hood Logo
93 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
