Question about Dell Inspiron Computers & Internet
I have a dell inspiron and it keeps randomly rebooting and crash dumping every 30 minutes with a blue screen.
    Problem Solver:
  • 19 Answers
Maybe a defect in the hardware: Bad power supply, dying hard drive, dying ram. Try to test these parts one by one.
Posted on May 14, 2014
SOURCE: blue-screen crashes
I just had this problem too, I had to replace the hard drive ($94) and lost everything. easy fix though.
Posted on Jan 25, 2008
joey64
  • 209 Answers
SOURCE: dell inspiron 1720 reboots randomly
there are several reasons why a pc restarts: 1. there might be a virus that causes this, thry to scan your computer using the updated anti virus. 2. your power supply might be faulty, if your pc frequently restarts the 12volts supply is having a problem, you need to replace the power supply. 3. operating system error, you need to repair your OS. what i have suspected from the problem you relayed is that your power supply, you need to replace this.
Posted on Apr 29, 2008
  • 17 Answers
SOURCE: dell inspiron 6400 rebooting
it is an issue with your software which is not able to find the os in hard drive please perform a operating system reinstall
  1. Ensure all of the Windows XP installation discs and information are present.
  2. Install the Windows XP disc.
  3. Press and hold <Ctrl>+<Alt>+<Del> at the same time to restart the computer.
  4. When the computer restarts and the Dell splash screen appears, press <F12>.
  5. In the Boot menu, use the <Up> and <Down> arrows to select either CD or DVD, and then press <Enter> to continue.
  6. If prompted, press any key to continue. If you do not press a key, the computer starts from the hard drive. In that case, wait until Windows has completed started up, and then begin again.
  7. At the Windows XP setup window, select To set up Windows XP now, press Enter, and then press <Enter>.
  8. Press <F8> to accept the terms and conditions specified in the license agreement.
    new_note.jpg Note: By default, unpartitioned space is highlighted. If any other partitions appear that were not previously created by you, they may include a PC Restore partition or a Media Direct partition.
  9. In the Windows Setup Partition screen, press <Enter> to partition the hard drive. On this screen, review the listed partitions. Usually, the original operating system partition is labeled (OS) and is also the largest partition.
  10. Use the <Up> and <Down> arrows on your keyboard to highlight the OS partition and press <D> to delete the partition.
  11. When the Confirmation screen appears, review the warnings and press <Enter>to continue. You will now be returned to the previous screen.
  12. Use the <Up> and <Down> arrows to highlight the unpartitioned space and press <Enter> to set up Windows XP. The Windows XP Setup appears with the following information highlighted: Format the partition using the NTFS system.
  13. Press <Enter> to continue. On the next screen, a progress bar shows the format process. When the format is complete, the setup files are copied to the hard drive.
    The following message appears: Please wait while setup copies files to the Windows installation folders. This might take several minutes.
    Then follows Setup is copying files…. The status bar displays the percentage complete. When complete, the computer reboots and the set up wizard appears.
  14. When the Regional and Language Options window appears, change as needed, then click Next.
  15. When the Personalize Your Software window appears, enter a name and organization if wanted, then click Next.
  16. When the Product Key window appears, enter the product key, then click Next.
  17. When the Computer Name and Administrator Password window appears, enter a password if wanted, then click Next.
    When you enter the password, be sure the caps lock is off; passwords are case sensitive.
  18. When the Date and Time Setting window appears, change as needed, then click Next.Windows is installed, a progress bar indicates approximately how much of the task is complete.
  19. The computer reboots.
    The Windows XP operating system is fully installed.
Posted on Aug 14, 2008
rockitman187
  • 2559 Answers
SOURCE: Bad Pool Caller message??
BAD_POOL_CALLER is a stop error message that is caused because of problems with the memory management.
There is a list of more than thirty such causes that can give you this error message. If the stop error is consistent every time the system is rebooted, the following method will be effective in solving the problem:
* The hardware and RAM should be checked initially.
* Boot the system once again using the OS setup CD, or use a boot setup that has a GUI like BartPE.
* With RunScanner it is possible to use a memory test tool.
* Select a single account
* If all the accounts open then the system registry hive might be the problem.
* Locate the hive damaged and rename it, do not delete it.
* Create another hive from the backup or from the restore point.
* Initially uses the latest one and keep checking the restore points that come later.
* Avoiding harvesting any replacement hives from the hard drive booted Windows.
* After which compare the hives for differences.
This is one of the ways of fixing BAD_POOL_CALLER errors. Another method is to reinstall the OS but occasionally shows a disk read error or an error on the same lines. Switching the computer off for a minute or more and then switching it on can solve it since the error is only a slight glitch in the system operation.
The BAD_POOL_CALLER is seen for the first time after installing a hardware or software it is recommended that the computer be restarted. If it doesn’t solve the problem, the installation of the hardware or software should be checked for corrections. If the problem persists the installed hardware and software should be disabled, and the BIOS memory options like caching or shadowing should be disabled too.
The safe mode can be used as well to remove or stop components.
To enable the safe mode just press F8 when the machine is being restarted and select it from the Advance Startup options and correct the problem. The installation of the graphics card is another reason the BAD_POOL_CALLER error shows up. A simple reinstallation of the driver can solve the problem.
Microsoft has also acknowledged that the BAD_POOL_CALLER Stop 0xC2 error pops up when trying to print a document that contains a corrupt font.
A hot fix is available at www.support.microsoft.com
Posted on Jan 10, 2009
ButtFuzz
  • 463 Answers
SOURCE: My dell Crashes within minutes of turning it on!
This could be a multitude of things, but the first thing that comes to mind is an overheating problem.
To rule out other things, remove and reseat the RAM, HDD, CD/HDD drive, Battery, Wi-Fi/BlueTooth mini adapters, etc.
Also, for further clarification, is there any error indicated on the screen prior to the machine turning off?
Thanks,
Rob
Posted on Mar 06, 2009
Dell latitude 120l reboots in f8 screen then flashes blue screen or no boot able devices over n over
The operating system is crashing while starting, try to repair windows or format it again
Sep 07, 2013 | Dell Inspiron 3500 Notebook
Hi there, Our Dell Inspiron 1525 specs are as follow: Windows Vista Home Basic Service Pack 1 Intel Core 2 Duo T5750 @2GHz 2GB RAM - 32-bit OS Symptoms are: - Freezes oftenly after random period...
Do you have any CD's thatcame with your laptop? If so, look for one that has "Diagnostics and utilities"listed under the "Contents". You will have to boot from that CD disk. To dothis, power on your laptop and tap the key to bring you to the "Onetime boot menu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the32 Bit Dell Diagnostics". Next select the "Express Test" and see if any errorsare detected. If no errors are reported, then your operating system software isprobably the culprit.The blue screen of death can be caused by hardware or software. If Diags pass you probably have a software issue. If you don't have the resource CD press the key while powering the system on. This will run theDell built-in Diagnostics.
Feb 22, 2011 | Dell Inspiron 1525 Notebook
I recently bought a Dell Inspiron N3010 in September. Within the first few weeks of purchase, the laptop blue screened me. I maintain my laptops very well, and avoid downloading junk programs, as well as...
driver or hardware problem if it is happening when using the web cam and mic then thats a good place to start update the divers for them and see if it takes care of the problem
Jan 28, 2011 | Dell Inspiron 13R (N3010), 14R (N4010),...
Dell inspiron 1429 would not stop restarting
just read the error on that blue screen...Its a dump error....then tell me....
ashishcgaikwad@hotmail.com or on 9665071117
Aug 27, 2009 | Dell Inspiron 1420 Notebook
Inspiron 600 m Dell blue screen
Keep pressing F8 as the computer starts up, select "last known Good Configuration" from the menu.
Jan 22, 2009 | Dell Inspiron 600M Notebook
Blue-screen crashes
i suspect the cpu and or fan is defective
Jan 09, 2008 | HP Pavilion dv1000 Notebook
Turning on, crashing ans screen
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372718&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035372&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00037733&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
Computers & Internet Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
