Question about Electrical Supplies
Keeps tripping breaker on 30amp service
Whenever I run my drier...It runs for about 5 min. then blows breaker both drier and box 30amp.
  • 33 Answers
Sounds like you may have a weak breaker or under size conductors. For 30A you need at least 10 awg conductor. Did this help?
Posted on Jul 06, 2014
  • Lester Fortner
    Lester Fortner Jul 06, 2014
    By the way, Most dryers are 50 Amp. Are you trying to run a 50A dryer using only 30 A breaker and conductor. Check it out to be sure.
muttandjeff
  • 359 Answers
SOURCE: Main breaker tripping
replacing the main is a possibility and i saw someone suggestion to ck load on each leg of power , also a good idea but one thing i have also seen do this is a loose or corroded connection in the meter base or disconnect which causes a process called electrolysis that is a flaking away of the conductor itself in the meter base or disconnect feeding the panel main breaker and causing heat build up internal to breaker and making it trip but if you replace the main that is the time to check all these connection and it would not hurt to apply a little no lock or some other brand of oxidation inhibitor
Posted on Feb 07, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Looking for 2 15amp single pole pushmatic circuit breakers.
A Google search for "15 amp pushmatic" turned up several links. Here's one for a retailer with new ones and an eBay store with cheaper prices (maybe pullouts):
http://www.aplussupply.com/break/push/push.htm
http://stores.ebay.com/Sparkys-Place_Pushmatic-Categories_W0QQfsubZ10975954
Did you also check the big-box stores like Home Depot or Lowe's or electric suppliers in your area?
Posted on Feb 11, 2009
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
protek480
  • 1714 Answers
SOURCE: 50 amp GFCI breaker trips after spa runs for 45
More than likely, it's the element. They begin to 'leak' small current as they get old and this will trip the GFCI
Posted on Jul 11, 2009
  • 112 Answers
SOURCE: Breaker trips when running a small dehumidifier alone on circuit
the breaker is getting weak and won't hold the load, assuming that nothing else is on the line. if it trips immediately u could have a short.
Posted on Aug 22, 2009
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
Apr 29, 2016 | Stiebel Eltron TEMPRA 24 Tankless Water...
The tumble drier operates correctly but after a short time (eg 5 minutes) it trips out the fuse box and cuts out ?
you obviously have a short somewhere in the machine, Or its overheating due to bad venting, bad blower flow etc, it should not blow or trip ur breaker box though? has anyone bypassed any of the thermal fuses? I suspect u may have a short in the heater element broken wires touching metal and causing the fuse to trip
Mar 18, 2015 | Dryers
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Light downstair keep tripping our fuse box
Is it really a fuse box ? or breakers ? If nothing is running on that circuit ,you probably have a short circuit , the fuse or breaker is saving you from a fire.
Apr 30, 2012 | Cars & Trucks
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
A/C runs for 10 min then throws breaker
the 30amp breaker is bad but when running on a 20 which is good its not enough of amps to support thats why it ran for 2hours before it ..so try changing that breaker to a new one
May 15, 2010 | Coleman Mach III Air Conditioner
Outside unit trips the circuit breaker
seems that if it runs for 5 minutes there shouldnt be any shorted wires I would say your breaker needs replaced
Aug 04, 2009 | Weather King 10AJA6001AH Air Conditioner
Sde5401ayw keeps tripping breaker
ck the element if the breaker poping as soon as you use heat dead short eather element are wire going to it
Mar 18, 2008 | Maytag SDE5401AYW Electric Dryer
Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Oct 14, 2007 | Kenmore 62602 Electric Dryer
Clothes Dryer not working
if it is tripping the breaker right away there is an issue with the drier shorting to ground. unplug and look for a broken wire in the drier. if the drier runs for 10-15 min maybe 30 before it trips the breaker. there is a loose connection in the wiring. either at the junction box in the wall behind the dryer or at the breaker panel. If it is in the electrical I would call an electritian. Good Luck!
Sep 24, 2007 | GE DBSR453EBWW Electric Dryer
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
