Question about Peg Perego Prima Pappa Rocker High Chair 2005
Instruction manual Can the tray be put in a lower position baby is almost at chin level
Ice maker does not make ice
there is sometimes an armature that raises when the ice tray is full.you can raise this arm is you want it to stop making ice.look said arm and lower down into on position.it will fold down into a spot near the full level of the ice tray.
Aug 20, 2014 | Refrigerators
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
I have a Minolta ep4000 copier. The bottom letter tray platform where the paper sits on is stuck in a high position. The copier will not allow that tray to feed paper. I tried to turn the machine on and...
With the draw closed and the machine on is there a small wrench Icon on the control panel lower left. If so touch it screen will change then once on new screen open close the front door, see if that resets your draw electrical.
Apr 07, 2011 | Minolta EP4000/5000 CS/PRO Copier
RS 2545SH ICEMAKER
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 22, 2010 | Samsung Refrigerators
The chin vent on new arai rx7rr5
No trick, i thnk its broken. Warranty from dealer or £12.00 from any Arai dealer (in any colour!!)
Aug 11, 2009 | 2008 Honda CBR 1000 RR Fireblade
Maxi cosi mico car seat on bugaboo is not level with the ground!
you may have put the car seat brakets the wrong way round change them around and try again or go to www.buggypitstop.co.uk they are experts on bugaboos
Jul 14, 2009 | Maxi-Cosi Mico Infant Car Seat
How do i copy an A3 to A3 paper
put a3 paper in the paper tray and adjust paper size wheel on trays righthand side so it says A3 doh.....................................
Jul 08, 2009 | Ricoh Aficio 2015 Copier
Peg Perego Prima Pappa Rocker High Chair 2005 Logo
90 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
romney2012
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
