Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Processor how can i identify my processor is 32 or 64 bit
Good
Posted on Oct 10, 2007
If it is 64Bit Processor you will be having two processor entries in the Device Manager after expanding the Processor Tab.
Posted on Sep 28, 2007
  • ankam Sep 28, 2007
    If it is 64bit Processor you will be having two entries in the Device Manager...
2 Suggested Answers
SOURCE:
wayneard
  • 1901 Answers
SOURCE: Difference between 32 bit & 64 bit OS ?
Here is a link from Microsoft that answers some general questions.
http://windowshelp.microsoft.com/Windows/en-US/help/41531554-d5ef-4f2c-8fb9-149bdc5c8a701033.mspx#EO
Bascially 64-bit processing can access more information at one time which will in essence be faster. 64-bit processing can access more RAM. 32-bit systems have a 4GB max. 64-bit systems have increased security benefits also. There are more links on the page above if you want to go deeper.
Posted on Aug 28, 2009
Testimonial: "Thank you so much. That was all what I wanted to know."
Speedy eggbert does not play.
it's work on windows 7(32,64 bits)..an the password could broke whith 11111111111111111111111111111 at ending...;)
Feb 23, 2014 | E-Games Speedy Eggbert 2
Mx6955 processor support
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Aug 11, 2013 | ASUS Computers & Internet
What kind of cpu do i need ? i have asus p5nd2-sli motherboard with no cpu in it
Seems that you need Socket LGA775,and CPU: Pentium 4, CeleronD, Pentium D, Pentium Extreme Edition. For more Details go here:
http://www.google.com/products/catalog?hl=en&q=p5nd2-sli+motherboard&cid=13414569805758042878&os=tech-specs
Nov 16, 2010 | ASUS P5ND2-SLI Deluxe Motherboard
Hello, i have a 5yr old Dell Inspiron 6000 laptop that when powered on, the monitor is black? it worked perfectly fine the day before and was shut down in sleep mode. i read somewhere about a Hard...
try booting to external monitor if no video then you probably need video card. they are replaceable on this model. look on ebay I think there are 3 levels 32,64 and 128mbs.lookup how to replace Not all that hard to do just PATIENCE.
Sep 14, 2010 | Computers & Internet
I just bought a 62-bit processor laptop. Can I
I assume your talking 64 bit and 32 bit, No you cannot use 32 bit in a 64 bit processor. You may be able to do it tho' by changing the compatibility but it's easier to use 64 bit.
Jul 11, 2010 | Corel Paint Shop Pro Photo X2
32 bit or 64 bit?
Here are the motherboard's processor specs >>>>
Intel Quad-core CPU Ready
LGA775 socket for Intel Core 2
Extreme / Core 2 Duo / Pentium D / Pentium 4 / Celeron D
Processors
Compatible with Intel 05B/05A/06 processors
Intel
Hyper-Threading Technology ready
64-Bit Processing Technology
Yes the motherboard can be used with a 32 bit or a 64 bit processor.
Regards..
Nov 13, 2009 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
How do I exactly identify my M400 Toshiba laptop? To download updates I have to identify a submodel for my M400, but I can't find it anywhwere.
Look at the bottom / underside of your laptop. It will have a sticker with a serial no. and bar code. The same sticker or a sticker next to it will have the model, type and submodel listed.
You can use that. If you know how to open the BIOS of your PC then you can use that to identify the submodel. To access BIOS, follow instructions that appear on screen when you start your PC/Laptop. It usually flashes for a second.
Jul 26, 2009 | Computers & Internet
Overheating toshiba laptop
Find out where the heat is comming from. If the heat is comming from the area around the processor, you can try to reinstall the processor.
http://www.irisvista.com/
This site can help you greatly. It will show you how to replace the processor on this page.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
This page shows about the model that I think you listed and how to take it apart.
The main thing to do first is identify the source of heat.
Once you identify the source, try taking it out and reinstalling it.
If that doesn't work, the only other thing you can do is replace the part.
Remember that some toshiba laptops tend to run hot anyway. I have hade two of them. The less powerful ran fairly cool but the more powerful is pretty warm. There is only so much that you can do besides cooling pads and using it in a cool environment. Make sure not to obstruct any vents as much as possible. If the processor is hot and you tried reinstalling it with no success, you can do some research and find another processor that is compatible with your computer that naturally runs cooler. This is all I can tell you. If none of this helps, there isn't anything you can do. Hope this helps.
Nov 24, 2008 | Toshiba Satellite A135-S4527 Notebook
NEW PROCESSOR
Im not sure because Pentium D is quite old but is still an LGA 775 CPU. I have 20% chance that it will work.
Why do you want to change to Core 2 Duo anyway? Its not gonna benefit you much except maybe a bit more speed in GHz and a bit more Chache.
If you want to you can download CPU-Z to identify your CPU.
www.cpuid.com
Run the utility and go to the "about" tab and dump to text file (press the button at the bottom)
Copy the things to do with the CPU and reply. Then ill have a look.
Oct 08, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
