Question about Singer CE-100 Futura Computerized Sewing Machine
Singer future ce-150, the bobbing winder just stopped working. When I try to wind a bobbing it rotates a few times then all the error lights come on and blink. Have to turn the machine of to reset to continue with any work. I'm winding my bobbins on another machine, which is a pain.
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
dupina
  • 110 Answers
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Posted on Nov 11, 2008
nenndre
SOURCE: Singer 7444 won't wind the bobbin... please help...
I guess the machine was defective, i trade it to the new one, and the bobbin worked fine...
Posted on Dec 27, 2008
dupina
  • 110 Answers
SOURCE: Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Posted on Jan 12, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Jul 16, 2017 | Singer Sewing Machines
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
I keep getting error E5 when winding my bobbin
If you are winding the bobbin in the middle of sewing process, it is normal to get a notification (E5) that bobbin winder should be returned to the left position before continuing to embroider.
Jan 28, 2010 | Singer CE-200 Quantum Futura Computerized...
Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Jun 27, 2009 | Brother CS-8072 Computerized Sewing...
Bobbins
When you engage the bobbin winder it has a small rubber in which it makes contact with the driver rubber maybe that is not making contact, to stop the cotton from showing on the top, adjust the small screw on the bobbin holder tighter clockwise.
Feb 26, 2009 | Singer CE-200 Quantum Futura Computerized...
Problems winding bobbins on my singer 4622 sewing machine
I have two possible solutions:
1. you have the wrong bobbin and it doesn't grip the winder.
2. the small spring on the winder spindle is missing or bent, it is what applies pressure to the bobbin for winding.
good luck!
Jan 19, 2009 | Sewing Machines
Singer Futura 350
Dear Wendy,
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Nov 10, 2008 | Singer 7422
Singer model 7462 sewing machine
Sounds like there is thread around the bobbin winder shaft and the machine is unable to continue winding, needs stripping and looking at. This is not something you should attempt yourself unless you know what you are doing. A reasonable sewing machine tech should be able to sort it out in a few minutes.
Mar 28, 2008 | Singer 7462 Mechanical Sewing Machine
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
24 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
