Canon fax 8820
How to connect the canon 8820 with laptop
I Have canon xerox machine i want connect to my computer
if u have driver cd then download the driver & install it ur computer plz connect power cord to main supply & USB to computer if port conflict happens then plz release older device n add canon device
note canon & xerox are seperate company plz use copy word eg. canon copier,canon printer,canon fax machine etc
shahanawaz shaikh,India
Apr 12, 2011 | Xerox FAXCENTRE 2218 18PPM FAX
I can't print anything when connected to my computer
go to www.canon.co.za and download the drivers there!Run the installation and then connect the fax to the computer!Good Luck!
Apr 24, 2010 | Canon FAXPHONE L80 Laser
How do I set up to print wirelessly with a Canon MP 620 Printer?
Hi
Thank you for your query
To share your printer you will need to do the following
1) On your desktop Click on Start>Control Panel>Printers and faxes
2) Right click on the printer in question and click on sharing
3) Put a dot in 'share this printer' and give it a name
This has now made your printer a shared one on the network
On your Laptops click on Start>Control Panel>Printers and faxes
2) Click on Add printer
3) On the resulting screen put a dot in the option 'A network printer, or printer attached to another computer'
4) Then follow through and the printer you named on your network
This will add the printer to your laptop and will allow you to print
Do the same for the other laptop
I hope this has been useful
Mar 12, 2010 | Canon PIXMA MP620 All-In-One InkJet...
How can i plug my canon to my loptop tashiba because it dont have the usb.
Sorry to inform you that your printer can not be connected directly to your laptop. It does have network capabilities but that is optional, meaning some more hardware is required for you to connect to a network. You must get a USB printer port to be able to connect the printer to your laptop. However if you have a PC then the printer could be connected to the PC and PC to a network on which laptop is also a node. The printer would have to be made shareable.
Nov 15, 2009 | Canon Laser Class 310 Fax
How to clean MFC 8820 corona wire of drum
simple solution for cleaning any corona wires Use a lead pencil eraser Gently clean the corona wire, with light even strokes, Best solution (recommended to me by my Copier tech teacher)
Jul 09, 2009 | Brother MFC-8220 Fax
Dont know how to opperate the scanner
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-15
Apr 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Amilo d 8820
the other way you can get round this is to do a fresh install of windows, it will have the majority of the drivers installed
then the drivers you are missing you can collect from the manufacturers web site
so any registered windows xp disk will do it does not need to be
the specific recovery disk
Nov 04, 2007 | Fujitsu AMILO D-8820 Notebook
26 people viewed this question
k24674
jasbo
jasbo
