Question about Ovens
No power is getting into the oven and i have changed the fuse on the plug.
I have changed oven switch plus new elements and still oven does not work pls assist thks
Oven temperature will be controlled by a thermostat which might be separate from the oven switch. There possibly is also a thermal fuse or breaker to protect against serious overheating in the case of thermostat failure.
One of those devices or the wiring or connections is probably faulty and continuity should be checked through the circuit with an appropriate meter.
Feb 03, 2016 | Ovens
Miele 212 oven does not work. We have a Miele oven that does not work anymore. 220V gets to the oven and then nothing happens, no lights, no display, nothing... Advise anyone?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
May 18, 2015 | Miele Ovens
Troubleshooting power issues for whirlpool accubake double oven
5.Even a bad relay door switch will hinder your oven from operating.
Mar 02, 2015 | Whirlpool Ovens
There s no power to my oven
Good Morning Friend,
I understand that you are not receiving power to your Frigidaire oven, model# FEB30T7FC, even though the power is on to your home and the breakers have not been tripped. Please try the following:
    1)Be sure the electrical cord is securely connected into the electrical junction box.
    2)There is a possibility that the service wiring is not complete.
    3)There is also a possibility that there is a short in the cord or plug. Replace the cord or plug.
    4)The house fuse has blown or the circuit breaker has tripped immediately following installation. The house fuse may not be fully engaged. Check the fuse and screw or engage circuit breaker securely.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FEB30T7FC Stainless Steel...
No power after self cleaning
5.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
5.
Dec 27, 2012 | Belling Ovens
AEG RIP? No power to oven?
If you have replaced an oven element the oven will not work again until you have reset the clock.
Sep 14, 2017 | AEG Ovens
My oven does not turn on
HELLO.
It is obvious that there is no electric power supply in your microwave oven.
solution
The problem of your microvave is likely to be from the fuse or wiring connection connected to the panel.
What you need to do fix up the problem from easy to hard , first of all is to carefully unplugged the plug from the wall then allow it to relax for some time then plug it back again to the power supply correctly to see if the problem will be solve ,
Then take a look on the fuse and also the wiring mention above the fuse is some time located at the tip or the mouth of the plug depending on the type of the wiring connection on the oven or inside the oven it self which will need to be check on and same condition is apply on the wire as well.
Please get back to me for further instruction if necessary.
Thanks.
Sep 19, 2011 | Stoves 600GR Gas Single Oven
How to change the fuse in my oven
youll need to remove the unit form the cabinet and remove the back plate, its athermal fuse partnumber 9759243. not a glass type auto fuse. after yo uoredethepart it willbe easier to locate onthe back of unit. KILL THE POWER LIVE WIRES!!!
Mar 02, 2009 | Ovens
AEG Microwave oven MC2660E - no power.
Hi , open open the microwave oven check the fuse , if open replace with the new fuse .
Feb 17, 2008 | Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
