I have just bought a memory upgrade for my clevo d610s notebook but i cant find where the memory goes. there is no door on the back to access the ram like on other laptops.
This is not as easy as the trap door on the bottom but it's not to bad if you just take your time. Remove power supply and battery. Follow all safety rules.
The memory is located under the keyboard. Take your time, open the screen to full open position, locate the small slot to pry the strip around the buttons at the top between the keyboard and the screen. Slowly work around until it all pops off. Then you will see three small screws at the top of the keyboard, remove them and look for a small pry point along the side of the keyboard. Don't just pull it off as it is still connected via ribbon cable to the mainboard. You will see a fabric tab at the top of the connection, pull on that until it releases. And there you'll see the spot...You can only increase your memory to one gigabite...no more than 512 MBs in each of the slots. PC-2100 (266MHz). It does not support dual memory nor do you need to install in pairs. Put things back the way they came out and you are finished. Once you have done it, it is not bad at all...take your time and force nothing.
Hope this helps, please leave rating, thankyou kindly
Problem sorted. Thanks very much for your help!
