Question about Sony XR-C5100 CD Changer
Sony xr c5100 radio does not work
4 Suggested Answers
SOURCE: wiring color code for xr-c5100
I am about to sell one on eBay - here are the connections from the installation paperwork and connector that I have:
Top row, left to right:
White - Front Left (+)
Green - Rear Left (+)
Purple - Rear Right (+)
Gray - Front Right (+)
Blue/White strip - AMP REMOTE (Max 0.3A)
Blue - ANT REM (Power Antennta Remote) (12V, Max 0.1A)
Red - Power (Accessory)
Black - Ground
Bottom Row, left ot right
White/Black - Front Left (-)
Green - Rear Left (-)
Purple - Rear Right (-)
Gray - Front Right (-)
BLANK
BLANK
BLANK
Yellow - Power (Battery)
One of the BLANKs is for the "Light Blue - ATT (attenuation for car phone)", but it is unclear which one. This wire is not on my connection block...
The circular BUS line to the right of the terminal block is apparently for linking to a CD/MD unit (cable supplied with unit)
The Blue 3.5mm socket is for the RM-X45 Rotary Commander (which attaches to the indicator lever)
Important notes:
If there is no ACC power line in the car, do not connect the red lead.
Ensure the power select switch on the bottom of the unit is in the B position, then press the RESET button (behind the faceplate).
This means that the display will be off when the unit is not in use - avoiding a flat battery risk.
(Posn A is for normal use, with red line on ACC)
The RESET buttom should be pressed after installation, before initial use.
Hope this helps.
Posted on Jan 21, 2009
caroldon
  • 17130 Answers
SOURCE: My Sony xr-c5100 car stereo
It is possible that the mechanism is jammed and so there is no loading of the carriage to the system. when the tracks are selected please try and hear if there is noise of the loading of the CD. If not there is a failure of the drive, failure of the loading section both of which needs a mechanical check within.
Please also have the optical head cleaned.
Posted on Mar 18, 2011
gopakumarg43
  • 74383 Answers
SOURCE: The face plate for my
Hello
You haven't mentioned nothing about its other functions. Does it loads CD, plays it and so one. Only mentioned about its back face plate backlights only. If this is the only trouble, that is, the backlight only not lights up, it can be repaired. Not even back light, most of the faults can be repaired. Backlight is produced by lighting up LED [Light Emitting Diode]. It may fail as if a bulb fails. It can be replaced. If problem is not this much, and more, inform me by Fixya. OK.
Posted on Mar 26, 2011
How do I change the date on my sony xr c5100 face plate?
Go to this site. Dont click DOWNLOAD..it is in big letters-leave it alone.
Down to the right (Under the word DOWNLOAD in the green box) are pages you can see and when you roll your mouse over them, they say what page of the manual they are. You want Page 5. Click it and see what to do. Dont know if you can print it and I know you cant save it but you could do a PRINT SCREEN and then go to your WORD program in Accessories
on your computer and Paste. This will put the screen shot in Word and you can then save and print it.
Good luck...here is the link.
Sony XR C5100 Manual
Mar 19, 2011 | Car Audio & Video
Car Radio
what is the exact model / maker, and also the maker of your cd player..
tnx.
Oct 09, 2008 | Sony XR-C5100 CD Changer
Hi there! i have a clarion in my peugeot 406 (2001). anyone know where I can by the removable keys from? thank you in advance!
It depends whereabouts in the world you are
If you do not have a local Car Radio / Audio Store
then  try Ebay
If not successful then try Google with
clarion car radio extractor keys in the Search and make a choice of supplier in your country.
Nov 15, 2009 | Sony XR-C5100 CD Changer
Remove cd player from car
Have a look around this site for the removal instructions
http://www.fitaudio.com/
Sep 12, 2009 | Sony XR-C5100 CD Changer
My face plate was stolen, how do i get another one?
unfortunatly the easiest and probably cheapest thing to do it just cut the loses and purchase another head unit...
Aug 06, 2009 | Sony XR-C5100 CD Changer
Programing the channels
sounds like your missing the perminant supply check that teh yellow cable has 12volt supply when your car is switched off
Nov 23, 2008 | Sony XR-C5100 CD Changer
CDX A55 Error (Err-99)
Hi in most casses just unplugging it will reset the unit.
but this unit is very old and to be honest is probably ready for he knackers yard.
they did suffer a few problems....
Reagrds
Mark
www.blueice-electronics.co.uk
Apr 09, 2008 | Sony XR-C5100 CD Changer
Changing time on clock
right then...
switch unit off. (off button)
push and hold DSPL button for two seconds
the hour didgit should now flash
set the hour by useing the + and - select
when you have correct hour then push the SEL button then do the same for the minuites.
once time is correct then again press DSPL
Regards
Mark
Blue ICE
Feb 23, 2008 | Sony XR-C5100 CD Changer
Wiring color code for xr-c5100
Black - Ground
BLANK
BLANK
BLANK
Important notes:
Hope this helps.
Jan 08, 2008 | Sony XR-C5100 CD Changer
Car Audio & Video Logo
48 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
