Question about Plumbing
Just replaced cartridge on Moen 7580C and now handle will not stay up (open), it comes down and shuts itself off under the weight of the handle. How to fix?
  • 374 Answers
SOURCE: moen single tub shower handle insatll
The valve has a faceplate that attaches with two screws and depicts the hot and cold mixing scheme on it. in the center of this is where the valve stem is located. It has a chrome escutcheon that slides into the faceplate and over the stem.There is a small -U- schaped clip that slides into the top of the valve body where the valve stem is seated that retains the valve stem. With all this in place all you have left is the acylic handle that has a unique shape to it on the internal portion that corresponds to the shape and position of the valve stm. Align the handle and stem and push the handle on. A small screw goes into the center of the handle to attach it to the valve stem. LASTLY you should have the acrylic button that covers the screw holding the handle on. All you do is align it appropriately and push the button onto the handle. The chrome handle version is essentially the same but is retained by a small allen screw on the underside of the base of the handle. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Posted on Oct 22, 2008
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
jj505
  • 195 Answers
SOURCE: moen shower handle keeps turning it wont come to a stop
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
  • 94 Answers
SOURCE: Replace cartridge in Moen kitchen faucet and now
it probably has a plastic cartridge,remove it, and push the center piece out slowly and firmly. wipe this down,not completly this is what carries the wieght of the handle.give this a shot.
Posted on Apr 27, 2010
How do I replace the cartridge in my Moen 7065 Vestige Single Handled kitchen Faucet?
first the water needs to be shut off, then with an allan wrench if i remember it should be 1/8. the allan screw is located in the handle. remove the screw completely and under the handle should be a nut, with a crescent wrench remove the nut and the cartridge should be ready to be removed. it is going to be difficult to come out with out the proper moen tool but vise grips will help as you have to pull straight up. if you find a plumping wholesale and give them the model # they should be able to give you the right cartridge. or if you call moen the will ship you one either way it should be free as that is a warranty item.
Aug 26, 2012 | Moen 7065 Vestige Single-Handle Kitchen...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Hard to pull up handle
Are you asking about faucet handle or pop up drain . If you are referring to faucet handle the easiest thing to try first is to remove center cover from top of handle. It's the one with the moen insignia or name on it. These are usually just a friction fit so use a small blade screwdriver or knife blade to carefully remove cover. There is a screw that holds handle on cartridge. Remove screw and gently remove handle by pulling up. If you have not shut off water supply valves this will open valve and run water. Push down on carteidge stem to shut off water. Use a penetrating oil such as WD-40 and spray around cartridge.Allow a few mins. then pull cartridge stem up and push it back down several times spraying with penetrating fluid several times. You can move stem by gripping with pliers. This should help free cartridge . If this helps you can save on service call. Reinstall handle with screw and center cover. Hope this helps. Thanks
Nov 12, 2010 | Moen 1 Handle LavatoryWith Drain Assembly...
I just replaced the cartridge in a Moen single handle faucet which was leaking. Now when I push the handle down to turn off the water it pushes back out and a small stream of water continues to run. If I...
I have experienced this problem a few times in twenty plus years in the plumbing business. What I would do is get a moen brass cartridge and give that a try. Hope this helps you thanks
Nov 08, 2010 | Moen & Replacement Cartridge
Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
If you need further assistance please let us know.
Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Handle won't stay up
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Jun 05, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Trying to put new cartridge in my moen bathroom faucet and i don't know how to do it. It is a teardrop one handle faucet. Please help a single woman not have to call a plumber!!!
shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
Apr 25, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Jan 12, 2010 | Moen 7437 Chateau Single Hole Kitchen...
My moen model 3175 is leaking. What is the likely cause and how do I repair?
The cartridge is absolutely the culprit. Very good shower valve, however the cartridges do go. Shut the water, take the handle off, disassemble the face plate, remove chrome collar from body, remove retention split spring, pull cartridge itself straight out. Replace new cartridge in reverse order of removal. Cartridge can be found at home depot, or any plumbing supply store. Good Luck,
Steven
Oct 10, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Plumbing Logo
44 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
