Question about Carrier 38CKC042 Air Conditioner
Tuneup kit for BDP A/C model 5690J042
My BDP, 5-ton, a/c unit was installed in 1985 and the model # 5690J042 is shown on the plate. I need to tune it up,(tuneup kit to replace Starting & running capacitors, contactors, etc) but I can not find component part numbers, equivalents components or service manual. Did Carrier change its model numbering system? Can you help?
    Novelist:
  • 75 Answers
Hi, most of the time generic parts are used to replace bad ones. The voltages and microfarads or UF is what's important on the capacitors and the amperage and control voltage on the contactor. Your unit will not run better with new parts and I suggest your time and money be used to clean and check your unit instead of "tuning it up" with new parts. If the capacitors are swelled or leaking oil they need replaced. If the contacts are pitted or burned, they need replaced. The condensing unit will need cleaned from the inside out. Remove the fan assembly and spray from the inside out on each of the condensing coils to remove the debris stuck inside the fins. If there are oil ports on your fan motor, add about 4 drops of oil into both of them. The same on your inside fan motor. If it has a fan belt inside check it to make sure it isn't worn too badly. Adjust it if needed to give about 3 inches of play. Too tight will make your bearings go bad. Oil your bearings if the fan has then and they have oil ports. Check the evaporator inside to see if it has a blanket of fuzz on the side where the air enters it. It can be removed with a credit card when wet. Scrape along with the fins if it needs cleaned. With the unit running and the inside of the house fairly comfortable the large refrigerant line outside should sweat all the way up to the compressor but the compressor should remain fairly dry. If it does, you have a good refrigerant charge. With this cleaning and oiling your unit should work more efficiently and be ready for another year. NOTE: The heating/air-conditioning companies usually run a special on seasonal checkups. If you have one come out, Have them do all the above plus get your furnace cleaned and ready. If you want more information on the furnace, please let me know what kind it is and I will try to help. If this solution does not rate at least (ALMOST THERE) Please do not rate. Thank You. kstfas
Posted on Sep 28, 2007
  • Anonymous Sep 28, 2007
    My apologies to therinnaiguy. There were no solutions posted when I started mine. My hats off to you for doing the research.
    kstfas
  • 1,420 Answers
If indeed it is a Carrier 38CKC042 model and 208/230 single phase, you need part number HN51KC024 for your contactor and the Dual Capacitor is P291-4054RS. Your unit may have 3 more numbers on the manufacturers plate that will be required to verify these parts.
SOURCE:
Fuel system diagram
ever give it a tuneup this decade or last 60k miles.????????????
get the FSM. buy one , used.on fleabay, and be ready next time.
or
go to alldata.com login and read it.
also at mitchels.
what engine size.
is car a CARB. (yes)
on all cars, carb or EFI , starting is same (basics)
example. (classical)
does it crank robustly, yes,
Does engine have 150PSI WOT compression, times 4. (yes)
does it have, spark on all 4 cylinders and is it timed right. (strobe it for time to spec)
answer, yes, (examples) and is timed right.
now we land on fueling
in this case its a carb.
the first test is , is the fuel at the top mark for for float level.
yes, good, no , pump bad. or filter clogged.
ok next.
is the choke on,, but not 100% if 100 % it floods,
is it ok? the choke plate.?
yes.
ok i got every thing it takes to start and its not flooding.
so what is wrong, easy, the carb is TOAST , get a new one.
oops, nobody sells them. its too old a car. in most cases.
but in my cause, i rebuild them.
i restore old cars and motorcycles, (stock)
so can do it. some take 3 used junk carbs to get one working.
and a kit. i find the carb kit first.
then boil it out (Berrymens) then kit it and tune it like the FSM directs.
there did it all end to end.
most 28yo carbs are useless and long gone.
(cept after im done)
i put in butterfly shaft bushing, and kit them.
if they are corroded to dust the hit the trash.
Jan 01, 2014 | 1985 Toyota Pickup
I have a blown BDP 7.5 ton Condsor unit. The old unit is R22. I want to replace it with a new BDP which has R410A. Question: I am being told that If I flush my old R22 Air Handler Coil & install a TXC...
I've done what you are describing - "however" you could void the warranty on the new condenser - by not having 'matching' coils (inside/outside). I would do some serious checking with whoever you are buying the new condenser from.
Note: I would (if possible) go back with a R-22 condenser unit (price is about the same), and you would not have any 'warranty or matching issues' going on.
Jun 03, 2011 | Heating & Cooling
We are about to install a a new central heating & air conditioning unit in the family home where my brother lives. It has a 4 ton now. Can we up grade to a 5 ton? One dealer says yes- another says too...
Hi, go with the 5 ton unit. 12,000 btu's are not going to cause moisture or mold!! I have done this for 33 years, do know what I am talking about and would not steer you in the wrong direction. Go with the 5 ton unit, and remember this for some knoledge from me to you. For every ton of cooling, there are 12,000 btu's. You will find this number in the model number of the outdoor unit if it is a split, or on the pack unit data plate. Look for 060 on a 5 ton, and 048 on a 4 ton unit. Please rate me on this post and keep me posted on the out come.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration, commercial Contractor
Oct 23, 2010 | Heating & Cooling
What is the HP rating if a 3 ton air conditioner?
Hi, this depends on the compressor that is installed in this unit. It may be a Copeland scroll, a Tecumseh, its hard to say. Most compressors are around 2 hp for a 3 ton unit. On the data plate it will tell you the h.p. of the blower and condenser fan motors such as 1/4 h.p., or 1/3. If you can get the name and model numbers from the top of your compressor, you can call a a/c, Refrigeration parts house, wholesale and they will have it in there manuals. The B.T.U. rating for your compressor is 36,000. There are 12,000 BTU's per ton of cooling, this is something that almost no one knows, but now you do. If it were a smaller unit such as a 2 and 1/2 ton, it would be 30,000 B.T.U.'s. You can look at the model number of a unit and you will see numbers like this, 024, 2-ton, 030, 21/2 ton, and 036 a 3 ton unit and so on. Your compressor alone will be in the range of a 2 horse unit, which ever the brand of compressor they installed in it. Please don't forget to rate me on this as I know you will be kind. I will be here if you ever need help on repairs or trouble-shooting your unit in the future, just use my user name below.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 04, 2010 | Heating & Cooling
Voltage 1phase or 3 phase 240 volts BTUs M# 585epo36o75
Looking at the model number, it appears to be a 3 ton. (36,000 btu) Most all residential units are single phase and most all commercial are 3 phase. One way to tell, look to see if the compressor has a capacitor. 3 phase never use capacitors on the compressors as they are not needed. Some residential units have a "Dual" capacitor. That is, it has 3 terminals, 1 common, 1 for condenser fan motor, and 1 for the compressor. Also, this info should be printed on the unit's lable.
Good Luck and hope this helps.
May 09, 2009 | Amana Comfort Zone 12M32PBEH Air...
I need to tear down my transmission in a 1988 Chevrolet Cavalier Z24 2.8L i am fixing the clutch and i need diagrams on how to take it apart and put it back together
Below is process for removing and replacing the clutch assembly.
Hope this helps, good luck.
Regards,
REMOVAL & INSTALLATION
See Figures 1, 2 and 3
0900c1528003be16.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Exploded view of the clutch disc and cover assembly
  1. Disconnect the negative battery cable.
  2. If equipped with a cable clutch (1982-84 vehicles), disconnect the cable at the clutch release lever and transaxle, as outlined earlier in this section.
  3. For 1985-94 vehicles remove the sound insulator from inside the vehicle. Disconnect the clutch master cylinder pushrod from the clutch pedal.
0900c1528003be17.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Disconnect the clutch actuator (slave) cylinder line - 1995-96 vehicles
  1. Remove the transaxle, as outlined earlier in this section.
  2. Mark the pressure plate assembly and the flywheel so that they can be assembled in the same position. They were balanced as an assembly at the factory.
  3. Loosen the attaching bolts one turn at a time until spring tension is relieved.
  4. Support the pressure plate and remove the bolts. Remove the pressure plate and clutch disc. Do not disassemble the pressure plate assembly; replace it if defective.
  5. Inspect the flywheel, clutch disc, pressure plate, throwout bearing and the clutch fork and pivot shaft assembly for wear. Replace the parts as required. If the flywheel shows any signs of overheating, or if it is badly grooved or scored, it should be refaced or replaced.
0900c1528003be18.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: You must follow the specified sequence when tightening the pressure plate retaining bolts
To install:
  1. Clean the pressure plate and flywheel mating surfaces thoroughly.
  2. Position the clutch disc and pressure plate into the installed position, and support with a dummy shaft or clutch aligning tool, tool J 29074 or equivalent. The clutch plate is assembled with the damper springs offset toward the transaxle. One side of the factory supplied clutch disc is stamped "Flywheel Side".
  3. Install the pressure plate-to-flywheel bolts. Tighten them in the sequence shown in the accompanying figure, as follows:
    1. Tighten bolts 1,2,3, then 4,5,6 in the sequence shown to 12 ft. lbs. (16 Nm).
    2. Tighten bolts 1,2,3, then 4,5,6 in the sequence shown to 15-22 ft. lbs. (22-30 Nm) plus an additional 30° turn.
    3. Remove the clutch alignment tool.
  4. Lubricate the outside groove and the inside recess of the release bearing with high temperature grease. Wipe off any excess. Install the release bearing.
  5. Install the transaxle, as outlined earlier in this section.
WARNING When adjusting the cruise control switch, do NOT exert an upward force on the clutch pedal pad of more than 20 lbs. (89 N) or damage to the master cylinder pushrod retaining ring may result.
  1. For 1985-94 vehicles, attach the clutch master cylinder pushrod to the clutch pedal and secure with the retaining clip. If equipped with cruise control, check the switch adjustment at the clutch pedal bracket. Install the sound insulator.
  2. If equipped with a cable clutch, attach the clutch cable at the transaxle and clutch release lever. Check the clutch operation by lifting the clutch pedal up to allow the mechanism to adjust the cable length. Depress the pedal slowly a few times to set the pawl into mesh with the quandrant teeth.
ADJUSTMENTS
All 1982-84 models have a self-adjusting clutch mechanism located on the clutch pedal, eliminating the need for periodic free play adjustments. The self-adjusting mechanism should be inspected periodically as follows:
  1. Depress the clutch pedal and look for the pawl on the self-adjusting mechanism to firmly engage the teeth on the ratchet.
  2. Release the clutch. The pawl should be lifted off of the teeth by the metal stop on the bracket.
On 1985 and later models, the hydraulic clutch system provides automatic clutch adjustment. No adjustment of clutch linkage or pedal position is required.
May 04, 2009 | Chevrolet Cavalier Cars & Trucks
Air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Apr 14, 2009 | Carrier 38CKC042 Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
392 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
