Question about Pioneer Elite PRO-940HD Television
Remove stand im looking for the stand for the bottom ob the tv
Cant remove stand from LC46SB54U - dont see 2 prongs going into back of TV...this is what my model looks like. http://lcdtvsale.devhub.com/blog/167586-sharp-lc46sb54u-46-inch-1080p-lcd-hdtv/
Look at page 7 Quick reference section
for similar model here:
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC46_52SB57UN.pdf
If the mounting mechanism is similar you will need a hex key and loosen 2 pairs of screws on the back near the bottom. The stand should then slide out from the bottom edge.
Oct 18, 2012 | Sharp LC46SB54U 46 in. LCD TV
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
Im having trouble removing the base stand, I'm trying to mount it on the wall. I removed the 4 screws on the bottom but cant get the metal legs off.
Generally the stand is screwed on from the back of the TV. there should be 4 screws that will come out all the way and allow for the stand to be removed
Mar 13, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
How do you remove the bottom stand from the TV set so you can hang it on the wall? I have unscrewed the bottom of the stand, but there seems to be something internal keeping it attached to the TV.
Most flat TV's actually have the stand held on by 4 screws on the back of the TV, not the bottom. Look closely and you should see them down 4 small holes. These hold the stand on. I think what you may have done is taken the bottom plate of the stand.
Hope this helps
TV_Doctors
Jan 06, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Remove stand of bottom of tv
I need to take the stand off my 42" jvc to mount it on the wall. How does it come off
Feb 04, 2010 | Televison & Video
I have an HCT LCD TV. It is an 32'' and I can't get the stand off.
"S" = Stand.
Remove the 4 screws and pull the stand straight off the bottom.
Joe
Jan 04, 2010 | Televison & Video
Stand wont come off grundig tv model gu19wdvd3 to mount it
Remove the three screws from the back of the stand.
Remove the four screws from the bottom of the stand.
Looking down at the bottom of the stand, push the four protuding clips inwards (not easy - you may need to gently ease them with a small screwdriver)
This unclips the oval base and allows you to unscrew the remaining screw inside the stem of the base
Dec 26, 2009 | Grundig GU19WDT 19 in. LCD TV
Need to remove stand from small Polariod TV
When you remove the bottom of the stand the silver plastic oval will remain attached to the TV, look in the bottom of it, you will see a small screw, remove it and slide the silver plastic piece to the left and remove it.
Thats it
Nov 19, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Im wanting mount my 37 in toshiba regza but i can figure out how to take off the bottom brace that supports the tv as it stands. i have taken off all the screws but the brace or base still wont come off.
Carefull turn the tv on it's back and remove the 2 black screws in the bottom of the stand in addition to the screws on the back that I assume you already removed.
Nov 10, 2009 | Toshiba REGZA 47HL167 TV
Remove base from television
Remove 2 screws on the back bottom by the stand.
Remove 4 screws, two on each side about 3/4 of the way toward each edge.
Pull TV up to remove from stand. Put plate and 2 screws back.
Can see this if you download the manual from the hitachi site. Just do a search for the model no. on their site's search engine.
Mar 22, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Pioneer Elite PRO-940HD Television Logo
14 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
