Question about Panasonic TH-42PX600U 42 in. Plasma HDTV
Remove stand pedestal
Want to remove pedestal stand and mount tv on wall. Have removed the actual stand but need to remove the circular collar and the two flat metal pieces that the top side of the collar fits into. The two flat metal pieces stick out away from the back bottom of the tv and does not allow the tv to fit "flat" against the wall below the wall mount. How do you remove the two flat metal pieces. It appears not all of the screws are easily accessable.
daniel719
  • 240 Answers
SOURCE: How do I remove a plasma panasonic mounted on a wall.
if it is a swing bracket 4 screws on back bracket holding it in need to be removed, if it is flat wall bracket lift strait up the wall to remove.
hope this helps
daniel
Posted on Jan 11, 2009
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
  • 92 Answers
SOURCE: removal of tv stand
The stand is usually held in by 4 Philips scres on the rear of the TV.
The stand itself has 2 "Arms" that point upwards, about 4 inches, they go up into the base of the TV, screws then go in from the rear of the set, low down, to secure the legs in place.
The stand, swivel mechanism and "arms" all stay together.
Good Luck, I hope it helps.
Posted on Sep 07, 2009
caroldon
  • 17130 Answers
SOURCE: how do i remove the stand/base off a panasonic
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Posted on Jan 07, 2011
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
Dec 18, 2012 | LG 42LG70 42 in. LCD HDTV
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 18, 2010 | Toshiba REGZA 47HL167 TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Open Questions:
See all Panasonic TH-42PX600U 42 in. Plasma HDTV Questions
Panasonic TH-42PX600U 42 in. Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
