Question about Whirlpool LEW0050P Electric Dryer
Check vent light is on. where is the vent - Whirlpool LEW0050P Electric Dryer
Why would check vent light go on after replacing sensor and computer
Is the dryer vent blocked with lint? If there is a restriction in air flow in the vent system, the dryer will stop. Make sure the vent path is completely clean even in the wall where the vent hose connects.
Oct 07, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Bosch vented dryer stops after a few minutes with drying and crease hold/end lights flashing
It could be that it is over heating. I would check the vent tube to see if it's clogged or check the part where you hook up the vent to the dryer
Nov 26, 2015 | Bosch Dryers
Dryer "check vent" light goes on
if air coming out back is strong it might be a bad sensor somewhere
Feb 11, 2015 | Dryers
My check vent light is on but is not clogged
Unhook the dryer from the vent and run the dryer. If the check vent light comes on, you have a problem with the dryer (probably the thermistor), if the light doesn't come on, then your venting system is inadequate.
Oct 18, 2014 | Dryers
Check dryer vent light comes on
check the back venting system and the front system still can be clogged by particals getting past the screen look inside the fornt system with screen out.
Apr 09, 2013 | LG DLE2516 Electric Dryer
Lg dryer check filter light wont stop blinking and the dryer wont work
You may have a clogged vent line.
Which will cause the check filter light to go on sometimes.
If the air is not getting out the vent and is blocked the sensor thinks the filter is clogged.
And you will not get heat either.
Check that the flexible vent line behind the dryer is not kinked or crushed.
A simple way to check if the vent line leading out from the dryer to the out side of the house is clogged is to remove the vent line from the rear of the dryer.
If the dryer gets hot when the vent line is removed, then the clog is between there and the outside vent door.
sometimes the little door outside the house gets stuck closed due to lint build up.
Or anything can be in the vent going into wall too.
Oct 20, 2012 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
My 05 Z71 tahoe blows air out of the front defrost vents no matter what setting its on. Also my check engine light is on.
The first thing I would do is have the computer checked for trouble codes. The codes will point you in the right direction to look for the problem. The codes may be for something other than the vent problem.
The air is directed thru the heater core and evaporator core and also to the correct vents by blend doors in the ductwork under the dash. They are usually controlled by small electric motors.
Jul 26, 2012 | Chevrolet Tahoe Cars & Trucks
2002 envoy gas dose not go into tank verry fast
There is a restriction either in the fill tube hose or the Evaporative Emissions (EVAP) vent system. A very likely cause is a Canister Vent Control Solenoid that is stuck closed. This can also be caused by a charcoal canister that is saturated with fuel or water. This will usually cause the engine computer to store a fault code and turn the Check Engine Light on. If the light is on, this would be the first clue. You should scan your engine computer anyway even if the light is not on, because some EVAP codes do not turn the light on and leave it on. There will still be stored fault codes in the computer if this is the case.
Sep 03, 2011 | 2002 GMC Envoy
My check filter light is on, the buzzer wont work but it is still drying
Hi
The electronic display on an LG dryer includes a "Check Filter" warning light. The light is primarily for convenience and does not indicate a major malfunction.
You may have a clogged vent line which will cause the check filter light to go on sometimes. If the air is not getting out the vent and is blocked the sensor thinks the filter is clogged. And you will not get heat either. Check that the flexible vent line behind the dryer is not kinked or crushed. A simple way to check if the vent line leading out from the dryer to the outside of the house is clogged is to remove the vent line from the rear of the dryer. If the dryer gets hot when the vent line is removed, then the clog is between there and the outside vent door. sometimes the little door outside the house gets stuck closed due to lint build up. Or anything can be in the vent going into wall too.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 02, 2011 | LG DLE2516 Electric Dryer
Check engine light
DESCRIPTION
A restricted or blocked evaporative emission (EVAP) vent path is detected by the control module monitoring the fuel tank pressure (FTP) during normal operation. The control module commands the EVAP vent valve OFF, or open, and the EVAP canister purge valve ON, or open. The fuel tank pressure should remain low as vacuum is drawn on the EVAP system. If the vent path is blocked or restricted, the vacuum level will increase and DTC P0446 will set.
DIAGNOSTIC AIDS
An intermittent Condition could be caused by a damaged EVAP vent housing, a temporary blockage at the EVAP vent valve inlet, or a pinched vent hose. A blockage in the vent system will also cause a poor fuel fill problem.
May 24, 2008 | 2002 Chevrolet Avalanche
Whirlpool LEW0050P Electric Dryer Logo
13 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
