Question about Dacor Cooktops
DACOR ru 465
I have a gas cooker DACOR RU 465 with the fan that moves up and down just do not work anymore.
Display panel dim
The display on my cooker started to dim until it finally went dark over a few weeks. Although a different make, I replaced the panel and everything is now fine. I was amazed how bright the new display was so it must have been dimming over a long period.
Nov 01, 2015 | Dacor Discovery ER30DSRSCHNG 30" Slide-in...
Severely reduced gas supply to hobs while grill
Valve at back of cooker that isolates gas to the hobs when the lid is lowered is sticking. Move lid up and down half a dozen times or oil it to ease it.
Dec 27, 2009 | Cooktops
The fan on my dacor stove top won't go up
This is a job for a qualified service Tech. The wiring, switching and/or motor mechanism could be the cause.
Aug 09, 2009 | Dacor Preference SGM466 Gas Cooktop
Too much noise with the fan, even at lowest setting. fan moving freely but may be slightly out of square.Metal attachments giving small vibration, can cure that w/ rubber gaskets. This is a Dacor pop up...
That is a bad fan bearing, rather than putting a rubber gasket I would replace the fan assy.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 28, 2009 | Dacor Preference SGM365SS Gas Cooktop
DACOR COOKTOP PGM-3651S
The top of the unit must come off. I suggest a qualified Dacor tech.
Mar 15, 2009 | Dacor 36 in.PGM365 Gas Cooktop
Pinnacle Raised Vent System #RV36 or RV 46
Ours started doing the same thing. I got it to start working again by gently holding down the up/down button until it started to move. After doing this a few times it started working normally again. Also the keypad can be locked and unlocked by pressing the low and high buttons together for 1 second.
Dec 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Converting LP to NG
The install manual on the dacor web site insists that Natural Gas requires the nozzles be removed, that low pressure NG works with the large 'default size nozzles'. Have done the conversion, in Australia, for my own barbecue, worked ok
Gas is too dangerous to make mistakes with. All I can suggest if Dacor is difficult is take the pdf of the installation instructions, link in the first replies, and the barbecue to a local gasfitter/plumber and ask them to work on it. they will be able to do the calculations from the existing nozzle size, lpg pressure, ng pressure, and required BTU output, to put in correctr nozzles
Dacor Australia are much easier to deal with.
(Now res in Canada,)
Bob
Aug 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
Converting Dacor ERD30S06CH/LP/H to Natural Gas
I know they won't convert gas water heaters but I didn't know they were afraid of stoves. See if your gas company will help. Sometimes they can drill out the orfices. Some of the older repair people still remember how to do this. The orfice for natural gas is larger as the pressure is a lot less. The gas pressure regulator will also need to be replaced. This can be done with a generic part.
Jul 12, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor Cooktop gas conversion
Where did you purchase the kit? Can you name the store with number or list the website? Also the part number information. Thanks
Sep 19, 2007 | Dacor Preference SGM365SS Gas Cooktop
Cooktops Logo
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
