Question about Kenmore 35 Pint Dehumidifier with Electronic Controls
KENMORE MODEL 251.50501010 WILL NOT RUN - Kenmore 35 Pint Dehumidifier with Electronic Controls
My Kenmore Elite Dehumidifier model 42-99701 runs but does not cool enough to collect water. Not a drop. found this page where I can order parts but I don't know what part I need to replace. Please help....
Dehumidifers are cheaply made and most likely it has formed a refrigerant leak. It would cost more to repair than to replace with a new one. They are basically a disposable appliance.
Oct 12, 2013 | Kenmore 54501 Dehumidifier
I have Kenmore dehumidifier 580.54701 70. Connected to external drain. Showing 01 code in humidity setting screen. Will not run. Approximately one year old.
Your model Kenmore Dehumidifier, I believe was was made my Haier, for Sears under the Kenmore name. In which case "01" indicates a circuit failure shutdown and needs to be repaired by an authorized Sears service technician. As it may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Kenmore 54701 Dehumidifier
Dehumidifier runs but extracts no water at all. room is 65degrees & humidity is 75%. no frost on coil & no moisture either. kenmore model no. 580.54501.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 15, 2011 | Kenmore Dehumidifiers
My kenmore model # 580.5450.1801 runs, but does not produce water. It is a humid basement, and another unit is working.
Turn the unit on and verify the compressor is running. If it is let it run for 3-5 min then unplug and plug it back in. If the compressor comes back on immediately there is a leak and the system needs serviced. If the compressor is not running further investigation to narrow down the cause is necessary. If the dehum is out of warranty replacement is the better option when sealed system repairs are needed.
Eric
Jul 16, 2010 | Kenmore Dehumidifiers
Our Kenmore dehumidifier (Model 580.53650200)runs but no water collects in the reservoir bucket. What could be wrong?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 18, 2009 | Kenmore 5365 Dehumidifier
Motor runs fan does not
you may have a stripped out fan unit, the fan motor runs, but the fan does not spin? my fan was plastic and stripped out there should be a flat spot the lines up with shafton motor ifit is round your should replace fan blade unit. i could not find one so i pushed tooth picks in between shaft an fan and glued them has worked for a couple months now
Aug 19, 2009 | Kenmore Dehumidifiers
I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
Jul 09, 2009 | Kenmore Dehumidifiers
Water not collecting in reservoir; seems to be building up in the top and running out left side (as you're facing unit)
Before I can fully troubleshoot this, what is the exact model of your Kenmore Dehumidifier. Please use the comment button to post up the exact model number.
Thanks
Jun 30, 2009 | Kenmore Dehumidifiers
Kenmore Dehumidifier Isn't Running
It sounds like you have power to the unit but a component is failing to start the system get an AC tech to check it.
Jun 08, 2009 | Kenmore 54501 Dehumidifier
Kenmore 35 Pint Dehumidifier with Electronic Controls Logo
109 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
