Question about Refrigerators
National nr-d38v3h - Refrigerators
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: the refrigerator is national "nr-302
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 17, 2011
Need new battery, of course I removed the battery some time ago to go and replace it. Yup its lost.
you lost your battery - bring a unit with you and ask for battery that fits in the store.
Dec 11, 2013 | Starrett D125 Digitape 1Inch x 25...
I have national Refrigerator NR 422-TE-G 2 doors which I bought from Saudi Arabia. This worked very efficiently for may years but now it is has defrost problem. Ice goest filled in freezer due to which fan...
Remove power and defrost. Check heater element behind panels in back of freezer. With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
Oct 21, 2013 | Refrigerators
Where to find the fridge door belt
what you are looking for is not a belt but a door seal
it is available from the manufacturer or service agent for the make
there may be door seal retailers that can make seals to suit your door on site ( mobile operators--using names such as seal-a fridge etc))
going google and typing in--- service agents for national refrigerators in ( your location) will get you an address and phone number
mostly any fridge /freezer repair shop will be able to suggest where to get the seal from
Feb 26, 2017 | Cameras
Need a replacement battery for Dl1/3N duracell 3v
Here is a list of equialent batteries that are calimed to be able to replace the one you specify.
Equivalent Batteries Cross Reference: Duracell DL-1/3N, 3N, Ray-O-Vac 867, 2L76, Energizer 2L76BP, 2L76-BP, CR1108, IEC CR11108, CR1-3N, DL1-3N, Dantona Comp 15, Duracell DL1/3N, NL1/3N, Energizer LR1/3N, Eveready 2L76, L76BP, I.E.C. 3V CR1/3N, CR1/3N, CR11108, Innotek M041101, Kodak K58L, National HM-N, NR-52, NEDA 5008L, 5008LC, Nikon F-1, Sony CR1/3N, Varta CR1/3N, LaserMax LMS-1/3N, LaserMax LMS-1/3N 5PK, LaserMax LMS-UNI-G
May 17, 2011 | Starrett D125 Digitape 1Inch x 25...
I have a national NR-302TE-X fridge for the past 4 months the fan in the freezer gets frozen and stops due to this the fridge does not cool and a lot of water is defrosed and there is water inside the...
dear
there is a temp, sensor in side the fridge that turn on a heater rod and stops compressor that melts the ice at back of freezer and fan.
or toy can open rear panel in side freezer and pure hot water (not boiling ) on frozen ice on condenser coils, this will help you for on week and then you have to repeat it again
you need a good tech person to solve that problem
hope toy under stand
?Adnan : eng-adnanpaul@hotmail.com
Nov 13, 2010 | Refrigerators
DEFROST TIMER FOR NATIONAL REFRIGERATOR NR-302 TE-G
the defrost timer have a motor inside it......it act as a watch, in every 8 hrs it defrost if the problem lies in it than you need to replace it as because it is not repareable
Jun 16, 2009 | Refrigerators
Where can I find a service manual (with electrical wiring chart)for rice cooker w
Where can I get the replacement thermal fuse you are talking about. The Oster service guy said they do not make them!?.NR
Mar 18, 2008 | Kitchen Appliances - Others
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
