Question about Craftsman Air Tools & Compressors
Need a 110 capacitor for a sears 919.185430 - Craftsman Air Tools & Compressors
Replace kenmore dryer drive belt
Go to www.repairclinic.com and enter 110.76902693. Be sure to enter the model exactly as I have shown. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of major parts.
Dec 07, 2016 | Kenmore Dryers
Can I bypass a starter capacitor to see if it is the problem why the motor is not working?
Sounds like more of a circuit/logic board problem than a motor..over the last 10+ years I've delt with a lot of openers that have had surge or lighting damage but never have had a motor go bad.
Nov 09, 2014 | Sears Craftsman LiftMaster Chamberlain...
How do I test the capacitor on a sears saw 113.199250?
I don't have the same band saw like yours. To check if the capacitor is bad, start by removing the blade for safety
Turn on the saw and spin the shaft by hand. Move hand away immediately. A good working motor will begin
running as you turn the shaft. If this is the case, you need to replace the capacitor.
Dec 02, 2013 | Craftsman Sears Radial Arm Saw Motor...
Model 16101690 Sear Washer wil not spin
If the wash and spin cycle is not working its probably the brushes need replacing on the motor
May 12, 2012 | Sears Roebuck And Co Washing Machines
I have a Kenmore washer model number: 110. 82427130. I need the washers large selector knob. Where can I obtain a replacement?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.+82427130&pathTaken=partSearch
Look at the section / diagram for the Console and you should see the part you need with the Sears part number and price:
The "Manufacturers Substitute" is a Whirlpool part number and you should be able to find one at a local appliance parts dealer.
If not, you can order one from Sears.
Apr 08, 2010 | Kenmore 24032\24036 Top Load Washer
Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Dec 03, 2009 | Craftsman Saws
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 | Plumbing
Sears 5 h.p. air compressor model 919176850 convert to 110 volt
pull the cover where the wiring goes into the motor, usually there is a wiring diagram on the underside. If not, go to sears online to see if you can get the manual for it
Jun 09, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
42 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
