Question about Air Tools & Compressors
5hp 230v Sanborn Magna Force (believe model 040-0205) keeps junking motors (i.e. they slow, hum, throw breaker, then "click" and won't start again). Been through 3 Marathon 5 hps in 2 months. Many now saying I have a different problem than trash motors, like bad unloader valve, etc. leaving too much pressure for start-up. "Sanborn" says not using an OEM motor and that a 5hp Marathon is underpowered and is likely the problem (I'm not buying it) - they also say it could be a head gasket, yadda... yadda. I can't figure out how to DIAGNOSE the problem without replacing every pricey part one-by-one until something works. Any suggestions? Many Thanks
  • 3 Answers
SOURCE: Campbell Hausfeld compresser throwing breaker
There is a one way valve that only lets air from compressor to tank. If this isn't working the motor is trying to start under the pressure of the tank, and therefore tripping your breaker.
Posted on Nov 30, 2008
  • 89 Answers
SOURCE: My Sears 1 HP compressor motor starts to slow down
IF IT HAS BELTS THE BELTS COULD HAVE BEEN LOOSE AND SLIPPING.. MOTOR COULD BE GETTING HOT DUE TO TOO SMALL OF CORD OR SMALL GAUGE DROPCORD. INTANK CHECK VALVE COULD BE GETTING CLOGGED NOT ALLOWING AIR TO PASS THRU IT. UNHOOK DISCHARGE LINE FROM HEAD TO THE TANK, THIS WILL ALLOW PUMP TO RUN UNDER NO STRESS AND SEE WHAT HAPPENS.
Posted on Apr 03, 2009
  • 1388 Answers
SOURCE: I have a sanborn magna
The web address below will provide you with the information necessary to order a belt for your compressor. Check the model number first however to insure correct part.
http://www.mastertoolrepair.com/165tgc51b850tgb8p165tg51h850tgh8p-p-1454.html
I have replace the V belt on my compressor with an automotive type belt to save money (and better quality). I used a tape measure around both pulleys to get the length. Check the motor/compressor for adjustability as this will help when tightening the belt. If the motor/pump is already positioned all the way out, re-adjust to closed position and remeasure. Now for width of the belt; automotive belts are sold by length and width and use a common numbering system of five digits. The first two numbers printed on the belt refer to the width and the last three refer to length. Measure the width of the pulley grove. My pulley measured about 1/2" . Auto belts were available in 13/16", 15/16" and 17/16" widths. These belts are marked with first two numbers as 13 or 15 or 17. Next use the measurement around the two pulleys. My compressor measured 47 inches around the pulleys. So the automotive belt number for my compressor is 15470. If the measurement around the pulleys was 471/2" then the belt number would have been 15475. The last number refers to 1/2" either a (0) or a (5) Most autopart stores will ask you for the year and model of car for your belt but ask to see the belts with tape measure in hand and check for size using the numbering system for a guide. If your compressor uses a flat style belt you can buy from www.grainger.com. Measure around the pulleys the same way for length. Good Luck with your project.
Posted on Apr 13, 2009
  • 67 Answers
SOURCE: Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Posted on Jun 16, 2009
  • 1274 Answers
SOURCE: I just hooked up a
Hi, my name is John. Welcome to FixYa. Make sure you are correct in the wiring of that, double check that you are right. Thanks for choosing FixYa....John
Posted on Nov 23, 2010
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
My jacuzzi clicks like it is going to start but does not.
If you have the proper voltage into and out of the time clock, you may have a bad start/run capacitor. I would need to know if it hums and then trips the breakers and if the shaft is free to the point you can turn the impeller with your finger.
Jul 18, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
The Electric motor does not have enough torque to start compressor. It is hooked up to 230V with 40 amp single phase. checked voltage with meter so I know it has enough voltage.
Does it trip the breaker or does the motor just hum and not turn the compressor? The motor may need a start capacitor. Do not keep tryin to start you can burn out the start winding on the motor.
TURN OFF POWER AND LOCK OUT.... try and take the belts off (if it has belts)of the motor and compressor and make sure both turn freely. IF THEY TURN FREELY THERE IS A PROBLEM WITH THE MOTOR. You said voltage, wire size and breakers are the right size.
Hope this helps you with your problem...Jim...please leave a comment
Feb 13, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Its a manual stop start controller with reset. push start button and strange humming noise for a short period then kicks out. could it be a capacitor
its probably the capacitor,if your lucky that is,if the motor bearings are freezing up from heat.age this repair can get expensive
Jul 26, 2010 | Pentair 5hp 1ph Single Phase 230v 60...
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
My motor just humms and will not turn. Pump turns freely and motor shaft? Humms for a will then will kick out, but does not throw the breaker. thanks, David
I'd replace the start capacitor on this pump, I believe. Be careful with this kind of electrical device: they store power and will kick you and hard if not wairy,
Oct 18, 2009 | Emerson Threaded 1.5hp Fullrate 115/230v
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Motor hums then clicks off
Has the motor seemed a little slower in starting than usual? If so then you probably have a weak or defective motor capacitor. Try switching out with a new one.They are inexpensive.Try to turn the motor shaft at rear (under end cap) while it attempts to start. If the motor kicks on then replace capacitor.
Apr 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
