Question about Xerox DocuColor 240 250 7655 7665 220v Fuser Cartridge 008R12989
Reset fuser 7655 - Xerox DocuColor 240 250 7655 7665 220v Fuser Cartridge 008R12989
Model 7665. What do fusher system errors 10.311.00 and 10.322.00 indicate?
Both of those indicate a defective fuser, replace fuser, part number 008R12988.
http://www.iteminconline.com/008r12988_008r12988-8r12988-622s00044-622s44-xerox-docucolor-250-fuser-assembly-110v-compatible-with-docucolor-240-250-workcentre-7655-7665-7675-7755-7765-7775-new.htm
Jan 10, 2016 | Xerox Office Equipment & Supplies
Workcentre 7242, it was showing 01-333 fault at first but after correction another error 010-319 how can i sort out this error code
Error 010-333 for this machine is "Fuser Center Thermistor Overtemp (Over temperature) or Overheat Error"
Error 010-319 for this machine doesn't seem to exist (Yes - I know you've got it - hence the problem post.)
Error 010-319 for other Workstation models (7655, 7665, 7675, 7755, 7765, 7775) is "Fuser Heat Control problem *NOTE: This code must be cleared from Diagnostic Mode"
As regards fixing this error the Xerox website should be helpful
Feb 16, 2014 | Xerox Office Equipment & Supplies
Xerox 7655 can it borderless print
No it's fisically not possible. There will always be an edge.
Try to print on a bigger piece of paper and cut it.
Apr 04, 2013 | Xerox WorkCentre 7665 Copier
How to delete all files at once on Philips Voice Tracer 7655
You can download the manual for this machine at www.dictation.philips.com in the support section.
Mar 07, 2010 | Philips Digital Voice Tracer 7655
How do you delete files from the Phillips Voicetracer 7655? Thank you.
Go to www.dictation.philips.com and download the user manual. Full details of deleting files are in there.
Nov 10, 2009 | Philips Digital Voice Tracer 7655
Xerox DocuColor 240 250 7655 7665 220v Fuser Cartridge 008R12989 Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
