Question about Dishwashers
Maytag dishwasher soap dispenser not open
Maytag model#MDB7749AWB1 I just had the control panel replaced and forgot to mention the dispenser door wasn't opening. I bought and replaced the entire dispenser, however that has not corrected the issue. Thanks
5 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 04, 2008
  • 114 Answers
SOURCE: Maytag Dishwasher Will Not Rinse
You are probably not getting enough water into the machine. Replace water inlet valve (solenoid valve) and this should solve the problem.
Posted on Dec 03, 2008
  • 22 Answers
SOURCE: Maytag MDB9150 Dishwasher soap dispenser door doesn't open
the plastic lock of the soap dispenser in side the dish washer door is broken
Posted on Jun 09, 2009
  • 457 Answers
SOURCE: Wet dishwashing soap
make sure that the you let the hot water run for 2-3 min to make sure it is hot going into machine or it will not break down the soap.if the dispenser is opening then it is a tempproblem. let me know if my assistance was any help with a 4 thumbs up post
Posted on Feb 27, 2010
The soap dose not dispence
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it
Oct 20, 2010 | Maytag MDB3100 Dishwasher
The soap dish opened, but the dishes were not cleaned. The soap remains on the door even after two or three wah cycles. Checked all of the buttons.
Since you mention that your dishwasher has a dispenser has a flap that opens but detergent does not come out, the problem could be the wash water is not getting to it.
Can you confirm if during wash cycle the water is circulating especially through the top wash arm.
Keep a small container on the top rack and see if there is water collected in it at the end of cycle. Alternatively run the dishwasher with door open (you will have to find a way to enable the door switch inside the latch).
Please post a comment to confirm what you observe.
Sep 07, 2010 | Maytag Dishwashers
Water is coming up through the kitchen sink when dishwasher is running and teh soap depenser will not release the soap.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these. Please do rate this solution and revert for further assistance.
Daniel
Aug 14, 2010 | Maytag Dishwashers
Soap dispenser won't open during operation
Hi
Daniel
Aug 02, 2010 | Maytag Dishwashers
Feb 27, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Soap dispenser door doesn't open for the second cycle.
Hi, the soap dispenser has a motor / solenoid which controls the latch that opens the door. This has gone bad and needs to be replaced. It is located inside the dishwasher door panel. Remove the screws around the inside of the door to gain access to the solenoid. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
make sure you have 120 going to the ax motor.. if you dont then replace the control.
Dec 01, 2008 | Maytag 24 in. MDB4000 Built-in Dishwasher
Soap dispenser
Item# 1405...$20.30
Item# 1434...$ 3.95
Jun 04, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
