Question about Radio Communications
Need asid tech hs01 tactile headset manual - Radio Communications
Where can I download a manual for a romantic z7000 Bluetooth headset?
Hello, Steven -
I think you must mean the Roman Technology (Shenzhen Roman Technology), a.k.a. "Roman Tech." Z7000 Neckband Bluetooth Headset user manual.
See it and download it here:
https://usermanual.wiki/ROMAN-TECHNOLOGY/Z7000/pdf
It is in Chinese and English. Since it is a PDF document, you will need Adobe Reader software (free.)
Best wishes.
Feb 21, 2018 | Radio Communications
My samsung tv has sound but no picture, there is just a faint blue out line around edges of screen
need to test lcd and circuit, you can't done , therefore pls send it to technician
Jun 05, 2017 | Samsung Computers & Internet
Need to pair my nokia5310 to plantronics explorer 210
You don't mention if this is your first time pairing the headset, you will need to turn on your blue tooth on your cell phone, the light on the headset should come on flashing red/blue. If it does not refer to sub pairing instructions below. The cell phone should find the headset. 2XX Plantronics in your list. If the pass key is needed it is (four zeros). Second time pairing or more than one device, turn on bluetooth feature, headset turned on, press and hold the call button for about 5-6 seconds. Release button and set headset aside. On cell phone hit bluetooth menu, search for add device. The cell phone should find the headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 17, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Cellular innovations HFBLU10K OWNERS MANUAL
hello all my name is lynwood i am a tech at Mizco Int'l you can email me at lynwood@mizco.com if you need a manual or any help on this product. thank you and have a great holiday season.
Oct 13, 2008 | Cellular Innovations HFBLU-CX1 Wireless...
The ear loop attached to my logitech F-0399A bluetooth headset has broken into 2 pieces. Logitech says since I didnt save my receipt, they were at a loss to do anything. Earphone works, I just need...
Ok, You can purchase an replacement part for the next generation logitech travelller Blue tooth. They fit fine .
If you cant find a replacement for the logitech travelller BT set, ask support to send you one and say you will pay up.
If you do buy , get a couple more
Else buy some gorilla glue and follow instructions to make a solid bond,
Bond one piece, Set aside for 12 hours,
Bond another piece and set aside for another 12 hours or over nite... The two pieces should now be solid bonded
Oct 12, 2008 | Logitech 250 Headset
Sticky middle button
This is a problem that can occur on this model after a couple of years. You can try a small amount of non petroleum based lubricant as a short term solution but the problem most likely lies within the small tactile switch that the button is actually depressing. The internal spring in the switch becomes fatigued over time and is a non replacable part. The headpeice should be available for purchase as a seperate item from your local headset specialist (we sell them here in Australia). It is a simple matter of registering the new headpiece to the base.
Sep 19, 2008 | GN Netcom GN 9120 Professional Headset
Need to purchase SMD Tactile Switch(es)
Fixya does not sell or source spares, parts or components
Jul 06, 2017 | Aiptek IS-DV Memory Card Camcorder
Radio Communications Logo
50 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
