How to add channels to shava tv box?? - Televison & Video
My shava tv box is not working pl help me sn no is 1080753177
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 05, 2017 | TV Box Televison & Video
Add a station
This set isn't capable of going over 68, this is all it's programmed for. You will need to get a channel box that overrides the tv's programming in order to add the channel 73.
Aug 27, 2008 | Sanyo DS20930 20" TV
My shava tv box get stuck on safe mode
Hi Nas!
I'd recommend getting in touch with Shava for some technical assistance.
Contact Us
Hope this helps!
Mar 08, 2015 | Televison & Video
I have to resetup all of my tv and cable channels
menu on tv.. click add channels one by one ..add them manually /it should highlight them a different color.. also be sure that your box and tv match as to which channel they come through on.. I just hook my box up to the AV in the back.. and S-Video.. (waiting to get HDMI) but it sounds like your tv isn't "smart" so do it manually, one by one and edit them
I also suggest switching to DirecTV
Sep 03, 2012 | Panasonic Televison & Video
Will not find digital tv stations
I'll be glad to assist you in locating the digital channels in the TV.
Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box.
To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database.
This should resolve the issue. Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Aug 04, 2011 | Sanyo DP46848 LCD TV
I need to tune my sharp tv to a set top box but am not having any luck. It only has an antennae connection and no AV channel. I have done an auto tune but cant get the set top box to work.
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
May 09, 2011 | Televison & Video
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
No channel 3, the tv goes from channel 2 to 4, can't use the cable box
Two options...
1. Connect the Cable Box via RCA cables (Yellow/Red/White) or Component cable if you have a HD cable box and select the appropriate input on the TV to view your programs. This will provide the best picture quality as well.
2. Make sure the cable box is on. Using the original TV remote type in the channel 03 and if this tunes to the channel then go to the TV menu and then go to Set up and then select add/erase and select add.
If typing 03 did not tune in channel 3 then using the TV remote select menu then go to set up and then make sure TV / Cable is set to cable then on the cable box press the channel button a couple of times and then select auto program on the tv.
Jan 03, 2010 | Toshiba 27AF44 27" TV
I can't progam the converter box whit the tv
Is the TV on channel 3 check the TV and see if channel 3 is deleted and re -add it and try again. Coverter boxes are channel 3 or even 4. without futher details on what your tryed please rate me accordenly.
Apr 22, 2009 | Televison & Video
Televison & Video Logo
310 people viewed this question
Top Televison & Video Experts
