Question about Siemens Washing Machines
I have a front load A07-16 electronic model. The issue here is once the washing process started, the drum rotates only for a second and then stops. It is filling water without any issue. It is continuously trying to rotate, but not able to speed up the rotation and finally stops (like not enough power to rotate the drum). The same issue shows in spin mode too (drum starts rotates but not able to speed up, then finally stops after 2 to 3 attempts). Please help me to find the root cause of this issue.
    New Friend:
  • 50 Answers
Fan belt not working - replace it
Posted on Oct 22, 2013
Testimonial: "Any idea, how much it will cost?"
  • 1462 Answers
SOURCE: Creda Excel 1200 W120VW Front loading washing machine
check motor brushes for a start
Posted on Jul 04, 2008
  • 67 Answers
SOURCE: Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Posted on Jul 14, 2008
    • 177 Answers
    SOURCE: Water leak under the rotating drum
    Have you removed the front panel?
    If not remove front panel two screws 5/16 on bottom
    Start the washer in a cycle. look with a flash lite and look for leak.
    It maybe the rubber boot.
    Please let me know if you have any other questions.
    I will also need model number, because a AWS52NW is a top loader model number not a front loader.
    T
    Posted on Jul 29, 2008
    SOURCE: no spin
    , Hi , My Zanussi Aqua Cycle 1000, Wash cycle (s) appear to start and run as normal, however the the Spin cycle does not kick in, it seems to try, both long and short spin functions have the same problem, also when I set the dial to spin out side of a wash cycle the result is the same , ie it trys to spin but fades after scaling up to very low revs....any ideas, could it be the Carbon brushes? if so are they easily obtained and fitted..Thank you
    Posted on Aug 28, 2011
    SOURCE: Program switch of Indesit-WD105T starts rotating
    I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
    Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
    Posted on Oct 08, 2011
    I dont have a stop buttom
    You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
    Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
    Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
    Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
    Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
    Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
    This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
    Mar 14, 2012 | Washing Machines
    My whirlpool duet (Model # WFW8400TW02 )washer stopped working. the steel drum is not rotating and clothes are not getting washed. please let me know what could be the problem.. --Ritu
    If this has a belt, then the belt may be broken or stretched out. Bad drum bearings can seize up and won't let the drum rotate anymore. A bad door switch can cause the machine not to run.
    Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
    If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
    Oct 24, 2010 | Bosch Washing Machines
    LG Washing Machine front loading, Model Fuzzy Logic 8.5KG,
    If it has a belt remove this then turn drum by hand to see if noise is still present if it is then sounds like some thing caught in between drun inner and outer you may need engineer....Pull plug out 1st...
    Mar 22, 2010 | Washing Machines
    What causes the tears in the bellow seals on front loaded washers
    It’s caused by gradual wear and tear through the vibration of the machine and rotation of the drum. If they are breaking down too often then it may be that your washing detergent mix or use of bleach or how you clean the bellows is weakening the rubber. Also excessive and heavy loads put more stress on the drum and can cause the drum to lurch dramatically from side to side which will end up in causing the bellows to wear / tear.
    Oct 06, 2009 | Washing Machines
    Drum doesn't really rotate on wash cycle.
    No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
    May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
    Washing Machines Logo
    230 people viewed this question
    Top Siemens Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
