Question about RCA D52W23 52" HDTV CRT TV
My rca 52"tv makes a hissing sound and shuts off when i try to turn it on
  • RCA Master
  • 3,438 Answers
Capacitor has blown you will easily find the fault when you take of the back and look and look at the power board it will be the one with the top round shaped or the one with a brown stain on the board around it. make sure you don't touch the board for around 10 minutes after the power has been turn'd off as this type of fault will leave volts in other parts of the board.
Posted on Oct 23, 2013
4 Suggested Answers
  • 1694 Answers
SOURCE: 52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Posted on Apr 15, 2008
fillmore85
  • 62 Answers
SOURCE: why does my 52 rca tv keep turning itself off and making a hiss?
Unplug the tv, take off the back cover and feel the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Posted on Jun 22, 2009
SOURCE: 52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Posted on Jan 30, 2010
When power it'll blink three times and shuts off
It is probably the power board. When the capacitors on the board fail they can make a hissing noise. If you look at the board and the small cylindrical things on the board ( which are the capacitors) are bulged on top instead of flat this indicates a failed capacitor. The board should then be replaced. Hope this helps.
Jan 01, 2014 | RCA D52W19 52" Rear Projection Television
My rca 52" tv was working this morning than shut
Replace the Deflection board. You can get the replacement deflection board from www.tvrepairworld.com
Nov 08, 2010 | RCA D52W19 52" Rear Projection Television
Please help! My stupid cat peed on my tv and it made this hissing loud sound and shut off! when I try to turn it on the button turns green three times and it makes this clicking sound? I paid 1,000 for...
More than likely, someone short circuited inside the TV.
The short term solution is to take it to a TV repair person (or in this case have them come to you).
The long term solution is to get a dog and get rid of the cat. The dog will be more loving, won't cause anybody to have an allergy attack when the visit you and will stay off of the TV. ;)
Oct 15, 2009 | Televison & Video
When I turn on the tv, it makes a sparkly sound and shuts off.
You probably have a high voltage failure causing the TV to sense the overload and shut off. There is about 30,000 volt required to light your picture tube focus the picture. If there is a failure anywhere in this circuit you will get the hissing noise and occasionally an ozone smell. I recommend you contact a TV serviceman to diagnose and repair this problem.
Oct 08, 2009 | RCA D52W23 52" HDTV CRT TV
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Oct 17, 2008 | RCA R52WH73 Projection Television
52 inch rear projection kept shutting off
bad flyback you can get a new one at the following link for about 50.00 they include free instructions and free tech support with every purchase so you can do the repair yourself. You need Flyback 259296 RCA Heres the link
http://servicemanuals.vstore.ca/
May 02, 2008 | RCA D52W19 52" Rear Projection Television
52 in RCA
The T.V. has no lamp, it has 3 guns red,blue,& green. Unplug the lead that goes to the high voltage splitter(make sure t.v. is unplug). Then turn the t.v. back on if you hear the H.V. lead making a hissing sound continuously most likely the h.v. block needs to be replaced. Follow the lead from the flyback to the h.v. splitter, this will be the lead that unplugs at the splitter.
Oct 11, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W23 52" HDTV CRT TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
