Question about Jandy Pool & Spa
No suction on jandy CL460cp. Think air in line, have cleaned all filters - don't know how to purge the line-
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Make sure top seal isnt damaged and make sure intake union is tight
Posted on Sep 25, 2014
2 Suggested Answers
  • 351 Answers
SOURCE: Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
Posted on May 04, 2010
The spa will not start - the pump is definitely connected to working power and the last time i tried it worked fine. However today when I push the on button nothing happens?
When you say nothing happens, I wonder if the unit is making any sound at all or do you mean there is no water flow? If there is no water flow in your hot tub or spa then it could be just a simple air lock. Often when you drain your hot tub or spa you have to prime the system afterwards, this includes the pump but may also include the suction lines. The suction lines can develop an airlock in the upper portions of the suction line. To remove an airlock you simply force water into the suction line or release the air in the line by opening a union. Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
Additionally, you could need new hot tub filters. If the filters are dirty and water flow is restricted your power pak may shut itself down as well. This can be as simple as cleaning your filters or replacing them. Hot Tub Filters
Here are a few things to consider
  • release any air locks
  • clean filters
  • make sure there is no obstructions in the lines
  • check to make sure GFCI is operational
I hope this helps.
Dec 26, 2015 | Pool & Spa
Not getting fuel in the filter
You can use low pressure from an air-compressor to blow out the INTAKE line from the tank to the filter to unclog the line. The fuel pump has a filter screen that may very well be clogged as well. Remove the fuel lines from the pump. Take out the screws that hold the pump face on, and remove the screen. Be careful not to rip the gasket when you remove the pump face. Clean the screen and re-install. While the lines are disconnected you can blow them out. After everytning is re-installed, the system may have to be purged of air. There should be purge valves on the side of the pump for this. As the pump is running, open the purge valve to allow any air in the line to escape. Also for future reference, the INTAKE line should be at least a few inches from the bottom of the tank, so sludge that settles to the bottom is not drawn into the line. It's also a good idea to use a anti sludge additive to the tank.
Hope this helps.
Apr 01, 2014 | Suntec A2VA-7116 Single Stage Fuel Pump
Igniter locks out
Ignition lock out will happen if the heater expects it to ignite, all things appear to be good, but ignition never happens. Check what the heater does not Know: is gas shut off valve open? Has the gas line been worked on - was the pipe opened up anywhere, like at the union? If so, then there is air in the line and air will not ignite. So, the gas line needs time to have the air purged or you can prime the gas line, but the best suggestion is to have a Professional do this!!!
Jan 31, 2014 | Jandy Pool & Spa
I think air got into the pool filter and now it has no suction what do I do to resolve the problem
There should be an air bleed valve at the pump. If not check or loosen the filter top to get the air out then start the pump after tightening the failter.
Oct 20, 2013 | Jandy Aqualink Pda P8 Wireless Pool or Spa...
WWas working just fine then hooked up vaccum and cleaned pool now the skimmer does not have any suction-- water blows out other side just fine and I have gotten all air out of lines--- any ideas
Depending on how much you vacuumed, your filter may just need to be cleaned. The filter on these units are not very big, so they can get dirty fast. Make sure it is cleaned out. Make sure skimmer basket is not clogged up, and make sure none of the flexible hoses are crimped. Also make sure there isn't anything stuck in the impeller. A stick, twig, or piece of toy, etc, can get stuck and cause low flow. Check for leaks between the suction side of the pump and the pool skimmer. One more think you might want to check is for leaks on the suction side while equipment is off. a leak here will let air into system and effect flow.
Sep 24, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Cannot get pool pump to prime
turn the valve to main intake line (not the skimmer) and flood the pump with as much water as possible.
make sure there are no areas around the seals where air could get sucked in. when you get a full flow switch it to skimmer and main.
May 10, 2010 | Garden
Could someone please confirm the order of operations for purging air out of the lines for a split system set up, using the refrigerant stored in the compressor. I have a 2 way 3/8" valve, and a 3 way 5/8"...
I think you really need a vacum pump, this will not only verify that you don`t have a leak, but will also
remove any moisture in the lines.
These companies that sell this stuff online, need to
remember that it is ilegal to purge refrigerant into the
air. If you hooked up a set of manifold guages, and
you seen the lowe sides pressure bouncing around
then you would know if you had air in the system.
You are better off trying to purge the lines with dry
nitorgen and then open up the compressor valves
Feb 18, 2010 | Heating & Cooling
Wont clear filter
If the clearing the filter screen will not go off then it is sure that compressor is not good.please check the compressor with vacuum gauge & make sure is has 13" HG of suction.
Aug 12, 2009 | Robinair Cool Tech 34700Z Recovery,...
The Intertherm AC Model B3BV-030K-A is blowing warm air
If you don’t see any frost on the suction line or big line on the furnace
(that goes from the furnace to the outdoor unit) and the filter and coil are clean then you are probably low on refrigerant.
Apr 14, 2009 | Heating & Cooling
Normal operating pressures
Normal operating pressures will change as the freezer reaches the selected temperatures on the inside. Normals of minus 14 degrees on the inside would be around minus 4 psi on the suction and 150 pis on discharge. Now checking the pressure will require a set of guages that have been purged with the same freon before connecting with the suction line on freezer. If not purged the suction line will draw outside air into the system and cause freezing of air and moisture inside the capillary tube rendering the freezer inoperative, Hope this helps, Sea Breeze
Nov 01, 2007 | Freezers
Pool & Spa Logo
32 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
