Question about SanDisk Sansa e250 MP3 Player
The whole thing is actin up im about to cry
Ok, so my E250 decided to act a fool. First, i trid to remove all the music files so i can add new ones, now it will not let me add any from my window media player. Every time i attempt the songs read error and refuse to upload. Secondly it will not charge. It has been on the charger for a day and only the black sandisk screen will appear, and doesnt change so i doubt its being charged. When i leave it alone then try to turn it back on it says battery is too low.ALso when i try to sync songs it will disconnect itself from windows edia player altho the USB is still plugged in. Im distraught Ive only had it for 7 months and i NEED my Mp3. Please Email me @ [email protected] when you have an answer that woudl be greatly appreciated *Kat
  • grammakat Sep 30, 2007
    i reseated the battery but still when i put it on the charger it will not move from the sandisk beginning screen. does anyone have any other suggstions?
  • 626 Answers
Kat, You have a few issues, but they are easily resolved. Battery - the battery inside has come loose from the contacts. You will need to remove and re-seat the battery to allow it to charge / function. Not able to transfer files - sounds like your device may be full or close to it. Best solution would be to format the device to remove all the music and start over. With the device connected, go to My Computer, right click on the device name (e250) and select FORMAT. Just click start and ok, to the delete all music prompt. If you are not able to format, change the mode on the device Settings>mode or USB Mode and try again. If you have more questions, just add to this one. Best of Luck.
Posted on Sep 29, 2007
  • Timothy D
    Timothy D Sep 30, 2007
    You can try this;
    Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
    http://www.sandisk.com/Assets/File/Downl...
    You need to put the device into "recovery mode" before you run the tool.
    - Turn the device off (hold power for 20 seconds)
    - Slide the hold switch into "hold" position.
    - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
    Then run the recovery tool. Select format when prompted.
    Best of Luck.
SOURCE:
How to put music on
http://www.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
Organize and transfer music and pictures with Windows Media Player11
4.1 About Windows Media Player 11
While your player will work with Windows Media Player 10, we suggest that you use
Windows Media Player 11 for a more enhanced media experience, both on the computer
and on your player.
Windows Media Player 11 is an all-in-one playback and recording program that lets you
play your CDs, rip CD tracks to your hard disk, transfer media files to your player, etc. This chapter describes the steps that you need to follow to successfully set up and transfer music and pictures to your player. For more information, see Windows Media Player Help on your computer or visit www.microsoft.com/windows/windowsmedia/player/faq/default.mspx
Important: Make sure that you have installed the Windows Media Player 11 software provided in the accompanying CD for music and picture transfer.
Although Windows Media Player also lets you transfer video files from your computer
to the player, please use the MediaConverter for Philips provided in the accompanying
CD for video transfers. For more information regarding transfer of videos, see 3.6
Transfer video.
4.2.1 Add music and picture files to Windows Media Player library
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
Add music and picture files that are stored elsewhere on your computer or
computer network
1 Select Start > All Programs > Windows Media Player to launch Windows Media
Player program.
2 Click the down arrow beneath the Library tab and select Add to Library ...
3 Click <<Advanced Options to expand the dialog box.
4 Click Add...
> Add folder dialog box appears.
5 Select a folder in which you have kept your music or picture files and click OK.
6 Return to Add to library dialog box and click OK.
> Windows Media Player will start scanning the folder and add available music or picture files
to the library.
7 Click Close when done.
Dec 28, 2010 | Philips GOGEAR SA6045 MP3 Player
Can't find music files
hai
it might be a virus attack
try this
brows the player on a computer.
from the folder option, make view options as
show hidden files
uncheck Hide protected operating system files press OK
if u can see all files, then select all files(Ctrl+A). Right click on a selected file, select properties. In the properties dialog box uncheck Hidden, System and press ok
Hope now u can see all the files.
good luck
Jun 17, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Make a copy of one of the files, and try changing the extension to .mp3.
Apr 18, 2008 | SanDisk Sansa e250 MP3 Player
Sync problems ...
The instructions with pictures are on pp. 13-19 of the user's manual:
Loading Music
You can transfer music from your computer to the Sansa player using the dragand-
drop method or using music managing software like Windows Media Player.
Drag and Drop
Follow these steps to drag-and-drop music to your Sansa e200 player:
1. Connect your Sansa e200 player to your computer.
2. Select Open device to view files using Windows Explorer on
initial connection.
3. Double-click on Sansa device.
4. Double-click on the MUSIC folder.
5. Drag and drop music files from your computer to My
Computer\Sansa e200\...\MUSIC.
Before you can create playlist and transfer (or synchronize) them to your
Sansa player, you need to show Windows Media Player where your songs are
located.
Adding Music Files to Library…
1. To add music files to WMP 11’s library, please follow these steps:
2. Click the arrow below the Library tab.
Loading Content 14
3. Make sure Music is selected then click Add to Library…
4. In the Add to Library dialog box, click one of the following options
then click OK.
- My personal folders:
Use this option to monitor the digital media files stored in your
personal Music, Pictures, and Videos folders, as well as any files
stored in the public Music, Pictures, and Video folders that everyone
who uses your computer has access to.
- My folders and those of others that I can access:
personal Music, Pictures, and Videos folders, the files stored in the
public Music, Pictures, and Video folders, as well as the files stored
Loading Content 15
in the personal Music, Pictures, and Videos folders that belong to
other users on your computer.
Mar 12, 2008 | SanDisk Sansa e250 MP3 Player
Adding music to my sansa e250
you must use windows media player 10 or 11 to sync songs into the sansa. Make sure you sync it this way or else your songs will not go in properly.
Jan 21, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs from Sandisk
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
Deleting files from Sansa e250
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Feb 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
