Rexel shredder HS.80
When I turn the shredder on to either Auto, Forward or Reverse, the motor is running and it looks like the little wheels are turning, but it will not pull the paper through
SOURCE: Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Posted on Jun 03, 2009
JayBlair
  • 328 Answers
SOURCE: durabrand shredder model wm6x runs in reverse but not forward
Try cleaning the sensors with a cotton swab and alcohol.
Posted on Jun 22, 2009
FixinFax
  • 3085 Answers
SOURCE: Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Posted on Jul 05, 2009
SOURCE: shredder motor will run in reverse, but not
The switch referred to above is the optical reader. I turned the machine off , and used windex to clean the optical reader area. It works...
Posted on Nov 25, 2009
SOURCE: Shredder is not working. Motor is working. It's
That sounds like the safety contact is not always making contact. The shredder has to be placed in the basket properly so that the little metal tab on the inside of the basket engages the safety switch. If not that, then I would suspect the sensor just inside the slot.
Posted on Sep 16, 2010
Rexel 100X. Why does it work for 2 seconds in reverse only, then jams?
From your description, experience tells me there is something jamming the mechanism. If plastic or clay coated material has been shredded, there will be residue between the grinding wheels that will require use of a utility knife and a pick to remove bit by bit. You will have to apply power periodically to rotate the mechanism and give access to new areas to be cleaned.
Dec 26, 2015 | Shredder Office Equipment & Supplies
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
My ativa hs 2000 paper shredder will only run in reverse
If the motor will only run in reverse and, you are stating that all the buttons are working. then most likely, internally the motor has burned out try tapping the motor lightly with a small hammer while the shredder is plugged in and on in the forward position. if the motor begins to move it will lead you to the answer of a shorted out internally motor.
Oct 15, 2012 | Office Equipment & Supplies
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Infoguard-10 sx100m motor runs, sounds like gears are turning , goes both forward and reverse. i cleaned all of the teeth, looks clean, but won't accept paper. i am handicapped and am having a hard time...
When motor is running, look to see if the cutters are turning. The cutters can be seen by looking into the throat of the shredder. If the cutters aren't moving, the gears may have been stripped and shredder needs to be repaired or replaced.
Good luck...
Apr 15, 2011 | Cross Infoguard Shredder SX102M
My RL170MX will only run in reverse mode. Forward and auto modes do not work. What controls the motor rotation ?
Motor forwards rotation is begun by inserting paper in betwen the 2 "eyes" in the paper throat of the shredder. They can become dusty/dirty and not function, if they are clean and yet the motor still will not turn in the forward direction it is possible the pcb inside the unit is faulty...contact Royal at 1-800-524-0799 for parts assistance.
Nov 12, 2010 | Royal RL170MX Shredder
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Paper jammed between blades
it must be a switch that percive papers. just in front of the where you giving paper.
May 29, 2009 | Office Equipment & Supplies
Jun 08, 2008 | Office Equipment & Supplies
jasbo
jasbo
