Question about Echo Garden
Shindaiwa chainsaw 300 360 377 fuel line - Echo Garden
Do I mix the fuel for my shindiawa 575 chainsaw
Re-fill with fresh fuel of the correct mixture
(Shindaiwa Premium 2-cycle Engine Oil
and gasoline-40 : 1 ratio;
other brands-25 : 1 ratio).
Workshop manual
http://www.golftechs.us/Manuals/shin%20chainsaw_current.pdf
Dec 12, 2016 | Garden
Shindaiwa eb802 hard to start
If it is not the fuel hose thats porous or bad tankairiation it will be also not the spark color red gaskets or ??? , remove the muffler and look at your piston side Look through the outlet port that it will have no grooves because you have lost compression on the piston by or a bad cooling to high rpm's and or bad fuel mix or (L + H) adjustment of the carburetor if there are grooves on the exhaust side
This is an little suggestion made by repair an other brand but it make no difference
Husqvarna husky 240 chainsaw Piston Cylinder Inspection
Mar 13, 2016 | Garden
Stihl fs80av
generally you have 1 line from the tank that has a fuel filter attached to it that goes to the inlet port on the carb, 1 line from the carb to the primer bulb, and 1 line from the primer bulb back to the tank. when you press the primer it draws fuel through the carb and returns it to the tank through the primer bulb
Oct 13, 2013 | Garden
I have an older shindaiwa 450 that has sat for a year in the house with no gas and was running well when I stored it but now it will start with choke on only and if it continues to run,it dies at full...
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. If this doesn't help, remove the carburetor, clean the interior with spray carburetor cleaner. Check the condition of the lower chamber diaphragm--it must be flexible with no cracks or holes. Hope this helps!
Jan 09, 2011 | Garden
Fuel mixture ratio
Oil Mix Ratio:
Starting in the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl and Tanaka all started recommending 50:1
  • 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen recommend 40:1
  • 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Jan 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
FUEL MIX
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 05, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need to know what the fuel to oil ratio is on my Stihl mini boss chainsaw
Oil Mix Ratio:
Your OM can be found here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If you want to verify my recommendation.
Lou
Sep 04, 2010 | Garden
Fuel oil mix for a Poulan 14" saw ?
Oil Mix Ratio:
Sep 02, 2010 | Garden
Oil to gas mix
Oil Mix Ratio:
Lou
Aug 10, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
What gas to oil ratio is needed
Oil Mix Ratio:
Lou
Jul 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
