Question about Samsung HCM4215W 42" Rear Projection Television
White tint/haze Not sure exactly how to describe the problem I'm having with my tv. It's kind of like a white haze on the entire screen. All three lamps seem to be working properly. One piece of information that might help diagnose the problem is that when I attempt to utilize the Perfect Focus feature, it gives me the following message at the top of the screen "No Sensor Data." Please let me know if you have an idea on what the problem is exactly. Thanks
  • Mattsoball Oct 01, 2007
    Thanks for the help, I looked at how much it might cost to have a technician fix the television and I don't want to pour that much into the tv.
  • SuperBird Nov 25, 2007
    My Mitsubishi WS-55907 just exhibited the same problem. White Haze over picture after about 15min. of on time. Looking for clues.
    Thanks,
    Virgil
    Genius:
  • 1,694 Answers
Check any/ all pico fuses in power supply. PVAT! Look for evidence of CRT coolant leak. Since Perfect Focus is a function of convergence,you might consider replacing convergence IC's,then perform alignment in servicer mode,then finish w/Perfect Focus.
Posted on Sep 28, 2007
Samsung UN55B7100WF has white haze on screen
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 30, 2016 | Samsung Televison & Video
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
When plugged into laptop, projects images with a purple haze
This will depend on the brand, model, cable connection type and OS of the laptop. Most have a color control which you can adjust.
Dec 05, 2011 | ViewSonic PJ350 Multimedia Projector
I have a Hitachi 55VS69A television. I replaced the bulb and not long after I did that I had a blue haze in the center of my screen. The blue haze spread to the right hand side of the screen, and now...
I have a Hitachi Ultravision. 55VS69A. It has worked wonders but now there is a blue screen in the center of the tv. Should I just replace the bulb. thank you.
alex
Apr 19, 2010 | Hitachi 55VS69 55" Projection HDTV
Three white dots on my screen!!!
This is a known issue with many Samsung DLP sets. The complete solution is here:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Be sure to read the entire post before acting to avoid being charged for the service.
Aug 18, 2009 | Samsung HLS4266 TV
PICTURE PROBLEM(white hazy picture)
hi, symptom is caused by mis-adjusted focus, theres mechanical adjustment on lenses, and theres electrical on focus block, if tv was recently moved I would guess it`s mechanical, I strongly recommend you get a tech to do this, good luck video-tek.
Jun 02, 2009 | Toshiba 50H82 50" Rear Projection...
Insignia 42" 1080p flat panel tv
you have lost your chroma (color) circuit the sepia you are seeing is just the black & white picture black and, white is adjustable from red to blue to green tint so; your sepia is an overloaded red circuit i could fix this but, i'm here and, you're there so take it to a serviceman it should not cost much more than $100
Apr 30, 2009 | Insignia 42" LCD Flat-Panel HDTV
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Samsung HCM4215W 42" Rear Projection Television Logo
122 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
