Question about Unsorted Parts Listing REGULATOR, LPG [KUBOTA WG750]
Looking for a dip stick for a Kubota model engine wg750-g
What's your question?my Isuzu 4ja1 engine .my problem is the oil comes from deep stick
i think you mean
when running the engine
the DIP STICK seal as it fits the dip stick tube end. leaks oil
this a bad PCV valve.
excess crank case pressures.... cause by not doing service on car.
or worse a very worn out engine with huge blow by gassed.
is engine miles high? over 300k? miles?
or the dips stick seal there is bad.... looking at it tells you that.
Sep 20, 2015 | Isuzu Cars & Trucks
Need parts list for kubota L1501
Kubota SHOULD have a support section on their website ,you need your model number and serial number etc ..but thats how I found one for mine ...also you could try typing Kubota L1501 in your search engine and look for a lawnmower repair website they are usually good at having stuff like that
Mar 12, 2015 | Kubota Garden
Where's dip stock for hydroloc fluid on a Kubota L3400 4x4 tractor
As a rule the Kubota L2800/L3400 do not have a dip stick for the hydraulic fluid. To check the fluid level, find the small round site glass that is on the transmission, left side, just in front of the clutch pedal. This sight glass has a level line on it. If the level is low the fluid might not show in the sight glass. If the level is below the line add fluid. The fill port for the Hydraulic fluid is on the back of the tractor just below the level of the seat.
Oct 31, 2014 | Garden
Don't know where the dipstickis i see everything else but the transmision stick. it's a 96
The transmission dip stick is on the left side of the engine toward the rear and has a red snap clip on it . Transmissions are always red and engine oil is always yellow so you don't put the wrong oil in the wrong place . However you didn't say what make or model but it will have a red dip stick pull out handle and every chevy i have ever seen for a 96 is in this area . Look around for it because its there and red
May 14, 2011 | Chevrolet Celebrity Cars & Trucks
Want to learn how to check transmission fluid on my ford mustang 1994
At the rear of the engine locate the dip stick going into the transmission case, it look like an oil dip stick. Pull it out and wipe clean. Re-insert pull out and read the fluid level at the bottom of the dip stick. Do this with engine off and on a level surface.
Dec 12, 2010 | 1994 Ford Mustang
How do i refill the transmission oil in my 1997 Micra auto (1 ltr). Can't find the cap.
Hi: To Refill your Auto Transmission with Tranny Fluid, There is NO CAP, Look For a Dip Stick Similar to your Oil Dip Stick.You Refill your Transmission where the Transmission Dip Stick comes out of a Tube. You'll Need a Funnel that Fits inside the Transmission Dip Stick Tube. This Should Resolve your Question. Please Vote and That actually sends me How Well I have Helped You. OH Look Towards the middle to the Back of Your Engine to Locate Your Tranmission Dip Stick: From the WYOCWBOY
May 30, 2010 | 1996 Nissan Sentra
Dipstick
if it is the 2.2 L motor it is right in the front of the engine just about center.
now just incase your looking for tthe transmission dip stick, on certain transmission models there is no dip stick for the transmission. it is sealed.
Nov 21, 2008 | 1999 Chevrolet Cavalier
Dip stick
the engine dipstick is in frt center of eng./the trans dip stick is yellow and on drivers side front of eng at the very bottom (you must look hard and move hoses and wires to get to it
Oct 19, 2008 | 2001 Volvo S60
Unsorted Parts Listing REGULATOR, LPG [KUBOTA WG750] Logo
Top Unsorted Parts Listing Garden Experts
Dennis Key
Dennis Key
john h
Are you an Unsorted Parts Listing Garden Expert? Answer questions, earn points and help others
