Question about Honeywell RTH111B1016/A Digital Thermostat
Rth111b1016 won't turn heat off - Honeywell RTH111B1016/A Digital Thermostat
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
My Marquis Randezvous Spa won't heat
It's one of 2 things. If the jets turn on but no heat, you have a bad pressure sensor or temperature sensor. If the jets don't turn on you have a bad pump.
Apr 02, 2013 | Pool & Spa
My mitsubishi galant temp control lever won't switch to heat
that happened to me the heater core went out ive read alot of different things about 03 galants most of them have the same problem it started with a grinding noise turning the temp contol, its actually the heater control motor value it causes the heater core to go out
Dec 27, 2012 | 2003 Mitsubishi Galant
Heat and Glo pilot light works but Burner won't go on. I messed with it and it started up but won't turn off. next day won't start but the pilot light is still on
light your pilot and take a light to the termopile (right beside your pilot it sticks out to get heat from your pilot. hold lighter for 5 seconds and turn gas on
Dec 08, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
Nov 06, 2012 | Microwave Ovens
My candy dryer is heating but the drum won't turn what can i do
replace drive belt contact manufacturer for agents for parts
Oct 06, 2012 | Candy Dryers
Whirlpool supreme lhi 5801 won't heat. The coil turns red but won't ignite anything. I'm pretty sure the gas is on. I don't know what else it could be...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 03, 2011 | Dryers
My oven stopped heating, and the range element won't turn red when you turn it on but it does have some heat coming from it. What's wrong with it?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
Aug 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Honeywell RTH111B1016/A Digital Thermostat Logo
52 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
