Comcast remote codes sony str-d511 - Audio Players & Recorders
3 Suggested Answers
SOURCE: left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Posted on Jan 22, 2009
  • 99 Answers
SOURCE: I have Sony STR DE845
If you consult the card that came with the remote, you will find several codes for "Sony". You will need to experiment with each code until you find one that will power the receiver on and off. Then you will have control of the receiver. If you don't have the card, then go to the web site and download a copy in PDF format from there. I have a lot of Sony stuff, and I have found that the codes varry according to the year the equipment was made and its function.
Posted on Aug 31, 2010
What is the remote code for comcast grey button remote for SONY STR DE835?
2285,2260,2263. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 16, 2014 | Xfinity NEW COMCAST HDTV DVR CABLE REMOTE...
Need Comcast 5-digit universal remote code for Sony BDP-S3100
Find Your Comcast Remote Control Programming Code
make sure your using those codes with the AUX button. Comcast does not have all remote codes for every electronic made though.
Feb 05, 2014 | Comcast Custom DVR 3 Device Universal...
Turn off dbfb without remote for sony md373
Sad, but true: without a remote it won't work. Had the same problem. Logetech Harmony 300 solved it in my case for a hcd ed1a. You can choose any sony device with a dfbf function. strangely for my modell logitech didn'nt support the bass boost function. so i searched for another version and found str-d511. with this device everything worked fine and i was able to switch the dbfb function off. you have to ad the bass boost function button manually. logitech harmony calls it bass boost, instead of sony dbfb. than ad this button to your device and you should be able to turn dbfb off.
Jan 23, 2012 | Audio Players & Recorders
Need remote code to program for universal remote
Code 31518 should work on your Comcast universal remote here is a link good luck! http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Oct 13, 2010 | Sony STR-DG500 System
I have Sony STR DE845 receiver and comcast red button dvr remote. Anyone know the code to have the comcast remote control the sony?
Aug 31, 2010 | Sony STR-DE845 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Code for Comcast remote for Sony DAVHDX275
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Sep 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Remote Codes for new Sony Bravia
I plugged this code in and it worked:
10000
Good Luck
May 12, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Left channel is out sony STR-D511
Stuart
Feb 21, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
