Question about Porter Cable-Cable Dado Throat Plate Insert - 38122
DADO THROAT PLATE FOR PORTER CABLE 270 WHERE CAN I
DADO THROAT PLATE FOR PORTER CABLE 270 WHERE CAN I FIND ONE
Need to purchase delta 36-979 dado head table insert for 10' table saw
Use an appropriate pc of mdf that is same thickness of throat plate already installed. Use a router to flush trim to that throat plate. Now, insert and hold down with clamps and scrap panel. Raise Dado head ,while running, enough to do the job. This completes a zero clearance throat plate. No need to buy!
Dec 31, 2012 | Delta 36 979 10 Inch Left Tilt 1 1/2...
I just received my new saw 22116 however their is no dado insert which I use a lot. on other saw i have bought the insert was part of the saw. i have tried to find it in parts so far no luck. ken parkins
If you are unable to buy an accessory throat plate from Sears for your saw, you might like to look online at www.manageyourlife.com. You may be able to find accessories there that your local store doesn't stock.
I'm not familiar with your particular saw and it's throat plate, but you should know that many woodworkers make their own inserts using 1/2" plywood cut to fit the shape of the throat plate. You can trace your existing plate onto the form, then carefully cut it out and sand to fit. Insert small screws from beneath the plate to level it in position, level to the table top. Then cut a slot in the new throat plate by raising a small blade up through the new plate. Sometimes I use a skilsaw blade or dado blade to make the first cut. Do this only when it is safely held down with a long board clamped over top of it, while you raise the spinning blade up through the new throat plate to cut a slot or groove, as the case may be. If you can't lower the plate over the blade in its lowest position, you can either use a smaller diameter blade to cut through it, or rest the plate lightly against a blade lowered to its lowest position, then hold the plate in place safely with a long board or piece of plywood that rests lightly against it and holds just enough pressure that you cnn start your saw with the throat plate against the edge of the blade, then exert slight pressure downwards to fit the throat plate fully into the throat, cutting through it into the backing board, then you'll be able to raise the blade through the throat plate. This is a dangerous operation and should only be undertaken with safety equipment such as safety glasses or goggles in place, and alway keep your hands away from the moving blade and exerting force away from the moving blade. Exercise good judgement and caution and you should be able to plunge the new throat plate into position over the moving blade, using the backing board as a safety device/push stick.
If you are unsure about any of these instructions please don't hesitate to ask further, or refrain from taking any actions on your own, and in any event, proceed fully at your own risk.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 11, 2011 | Craftsman Professional Premium Hybrid...
Yesterday I purchased a Porter Cable Jointer PC160JT from Home-Depot, Fairbanks. It was a floor model and as such DID NOT COME WITH ANY PAPERWORK. Is there any way I can obtain the owner's manual and or...
Hi psiaak,
You should have gotten all that when you purchased that equipment. If I were you I would go back and demand that paperwork, just because it is a floor model (demonstrator) you should still be able to get those papers. You should be able to go to the Porter Cable web site and get that. Hope this helps. All the best and good luck. Denis.
Mar 19, 2011 | Porter Cable Garden
I have a craftsman table saw model 113.27870. I need a table insert for a dado blade. I looked on the sears website and it said parts for this saw are no longer available. Will a table insert for a newer...
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Aug 02, 2010 | Craftsman 10" Table Saw
Need an instruction manual for a Model 557 Porter Cable Plate Joiner
Owners manual is here. Exploded diagram is here.
I would like to note the manufacturers site lists 557 Types 1-4. Not sure what the difference between them is, but if you need the link, it's here on page 4 of 5.
If this answer helped, please vote. Thanks!
Apr 10, 2010 | Porter Cable - Cable 557 Factory -...
Cutting 45's on my Dewalt 744
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Need dado throat insert for 113
why not just make your own out of 1/4" plywood
trace out the insert but don't cut a slot
install it on the saw with the blade all the way down
turn on the saw and raise the blade to cut out the insert
Dec 11, 2009 | Hardware & Accessories
Blade change problem for Porter Cable 557 plate joiner
Putting it in the freezer for a couple of hours may loosen the screw by contraction and or you will have to use an impact wrench unless it is completely stripped , then you will have to drill it out.
Apr 08, 2009 | Porter Cable - Cable 557 Factory -...
Bn125 brad nailer is jammed
I've had to remove the plate over the "firing pin" a couple of times (the allen wrenches come with the gun) to release it. Mine was caused by a bent pin, that happened when I hit the hose and knocked it off the bench.
When I finally replaced it (CPO/Porter Cable), it's been fine ever since.
Mar 31, 2009 | Porter Cable-Cable No.BN125A...
Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Mar 21, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Porter Cable-Cable Dado Throat Plate Insert - 38122 Logo
44 people viewed this question
Top Porter Cable Saws Experts
Dave
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
