Dell Inspiron blue screen, DRIVER_IROL_NOT_LESS_OR_EQUAL. Disable BIOS memory options such as caching or shadowing. *** STOP: 0x000000D1. (0x0000000000000004, 0x000000000000002, 0xFFFFF88004C88BD4) Technical information: *** arthx.sys - Address FFFFF88004C88BD4 base at FFFFF88004C6C000, Datestamp 4b8db121
Beni S-P
  • 1006 Answers
SOURCE: Blue Screen of Death
Just use ORIGINAL OS CD and repair OS everything will work fine!
Posted on Dec 28, 2007
  • 56 Answers
SOURCE: Blue Screen - indicating a problem
you possibly have a restore partition on your drive can you borrow a xp home cd from a friend if so let me know
Brian
Posted on May 26, 2008
SOURCE: After loading Window service pack 3 update, comes up blue screen
i think theres a spyware or u have to repair ur windows
Posted on Sep 23, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Posted on Oct 07, 2008
  • 3 Answers
SOURCE: i get a blue screen while trying to install new OS it gets to " installing windows" and then blue screen and error screen
ok this is the problem with the SATA controller , change the SATA controller in Bios to IDE or COMBI , n then reinstall ,it should work .if not try to install the SATA drivers externally n once u do that then try to reinstall the OS , it should 100% work !!!
Posted on Jun 25, 2009
Dell inspiron mini 10 Turn it on, put in password. screen says windows did not start up sucessfully. A recent hardware or software change may have caused this. then i go to the last known good...
A blue screen with white writing appears on my computer,
just before windows is about to begin and it reads:
A problem has been detected and windows has been shut
down to prevent damage to your computer.
UNMOUNTABLE_BOOT_VOLUME
If this is the first time you've seen this stop error
screen restart you're computer.
If this screen appears again follow these steps:
Check to make sure any new hardware or software is
properly installed. If this is a new installation, ask
your hardware/software manufacturer for any windows
updates you might need.
If problems continue, disable or remove any newly
installed hardware/software. Disable BIOS memory options
such as caching or shadowing. If you need to use safe
mode to remove or disable components, restart your
computer, press F8 to select advanced startup options,
and then select safe mode.
STOP: 0XOOOOOOED
(OX8OED4AF8, OXCOOOOO32, OXOOOOOOOO,OXOOOOOOOO)
I cannot go into windows even in safe mode, and I don't
know how to execute any of the other things it's telling
me to do.
It may have something to do with my virtual memory as
windows had to increase it while I was playing a computer
game, or because I added some extra pictures I downloaded
to a computer game folder where the default pictures were
already stored.
if u cant do these then reinstall the operating system.
Sep 03, 2011 | Dell Inspiron Mini 10 Notebook
Dell Inspiron 1525 Error Code 0333 Blue Screen of Death:)
Hello
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware and software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware/software, disable BIOS memory options such as caching or shadowing your computer, press F8 to slct Advanced Startup options, and then select safe mode
it could be a memory (RAM) problem. Many Dell's have a Diagnostic partition on the Hard Drive, accessed by F12 at initial boot up. If yours has this, run a complete diagnostic and see if there are any errors.
Try to reboot in safe mode using "last working configuration" and do an evaluation and see what comes up
Apr 15, 2011 | Dell Inspiron 1525 Notebook
My dell laptop suddenly started getting a blue screen error and crashing, the error is driver rlqc not less or equal, the laptop is still under dell warrantee is it covered by the warrantee if not how do i...
The Blue Screen Error IRQ Driver not less or equal is a memory problem. Basic things you can do is reseat the memory. However, I highly suggest to contact Dell and have them guide you in doing a Memory Diagnostics. They should replace it if its faulty.
Mar 30, 2011 | Dell Inspiron 1525 Notebook
Will removing the CMOS battery clear the BIOS
it's about the processor level caches
but also might be a bad memory slot (RAM)
resetting the bios is a good choice, maybe this will helpe either
Jul 01, 2009 | Acer Computers & Internet
How to remove BIOS memory cache
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
Mar 20, 2009 | Toshiba TECRA A6-EZ6312 (PTA60U05T00F) PC...
press f8 and go to safe mode and delete service pack 3. sp3 is known for problems
Sep 23, 2008 | Dell Dimension™ B110 PC Desktop
Computer on the blink
this is the'blue screen of death..the Dell model is usually on a tag somewhere on back. supply that, and perhaps you can gain assistance here(I'm Dell Certified going back in time, by the way)
May 08, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
