Question about Hoover U5172900 Fold Away Widepath Bagless Upright Vacuum
Not sucking dirt - Hoover U5172900 Fold Away Widepath Bagless Upright Vacuum
I have a Hoover Nano Cyclonic that doesn't use bags. My daughter took the entire bottom apart because it wasn't sucking up. So she tried to clear everything and also TRIED to put it back together.
You may have a clog in there somewhere,
but still enough suction to pick some dirt up but it doesn't get sucked into the dirt cup and falls out when you turn it off. If your filters are over a year old or not maintained or cleaned frequently they may be restricting the air flow which can lead to clogs.
Jan 31, 2017 | Hoover Vacuums
No suction
Check to see if you have a clog that is keeping it from sucking the dirt into the vacuum.
Jan 14, 2017 | Vacuums
My dirt devil wont turn on
first thing to do is to look in the dirt container for what masy have been sucked up.
Nov 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
Not sucking the dirt.
Check the hose...they plug up and then everything stops...
Here is a tip that I wrote after having the same issues with my Bissell...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 20, 2010 | Panasonic MC-V9620 Canister Vacuum
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Help!!!!
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Hoover U5172900 Fold Away Widepath Bagless Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
