Question about Garden
Homelite vac attack 2 pull cord won't rewind - Garden
KMusselmann
  • 247 Answers
SOURCE: pull rope broke
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Kurt
Posted on Mar 19, 2009
  • 86 Answers
SOURCE: Homelite VAC Attack II: starter cord will not pull
Did you have the right mix in it ? I have had them seem locked up but it was the starter cord came off pulley causing the rope not to move .
Posted on May 13, 2009
  • 5 Answers
SOURCE: Need a user manual for Homelite Vac attack 2
I have a Homelite UT08107
Leaf Vac, I couldn't get it started so I took it completely apart and cleaned it all up and now I can't figure out how to put it back together. I'm looking for a shop or a servive manual
Posted on Sep 04, 2009
bbreton
  • 437 Answers
SOURCE: does this blower use 2 cycle mix
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true.
Good day.
Posted on Oct 12, 2009
SOURCE: My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
Posted on Jul 18, 2010
Blower Vac HBL26BVN. The plastic primmer button has split. I cannot get a relacement. Help
Try this link:
http://www.ereplacementparts.com/homelite-ut08544-vac-attack-parts-c-18807_18808_139650.html
Jun 18, 2014 | Homelite Leaf Vac Attack
Why leaf blower hardly pull to star
RUNNING THE MACHINE WITH THE WRONG FUEL MIXTURE COULD BE THE FIRST CULPRIT. IF YOU WERE RUNNING TO HOT YOU COULD BE DEFORMING THE CYLINDER WALLS AND CREATE A PROBLEM THAT IS NOT FUN. TAKE THE PLUG OUT AND TRY TO SQUIRT A LITTLE WD-40 IN CYLINDER CHAMBER. WITH PLUG STILL OFF PULL CORD A FEW TIMES. SEE IF THAT HELPS. IF NO HELP MOST LIKELY BY A NEW ONE. GOOD LUCK PAL.
Sep 28, 2013 | Homelite 'Yard Broom' Leaf Blower
I have run my Homelite Vac Attack ii using gasoline only. Now it wont run.
You need to take to shop and have them check it out, more than likely the cost of Repairs will exceed the price of a new Blower, In other words Yes this Motor is NO GOOD . Sorry For the Bad News..
Oct 23, 2011 | Homelite Leaf Vac Attack
May 05, 2010 | Homelite Leaf Vac Attack
I have the homelite Vac Attack 2, i'm having trouble starting it, i prime it the desired 7 times (actually more) but i just sit there and pull, and pull, and pull the cord....really getting frustrated!
#1 senerio
Fouled spark plug
ie, carbon and or fuel fouled
install new plug, and withouth choking or priming, pull 4-6 times while holding the throttle at wide open.
If not fouled, go to senerio #2
#2 senerio
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 09, 2009 | Homelite Leaf Vac Attack
Homelite VAC Attack II: starter cord will not pull out. Feels like the engine is locked up.
May 13, 2009 | Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
